Machine isn't spining and the water is not draining...need to find what the problem is and how much to fix it.
Access the water pump and look for plugged drain hoses or a plugged filter as well as a slipping impeller on the pump shaft--or even a dead pump motor. Spin usually will not occur if there is a high water level in the machine. Try draining the tub into a bucket, then see if it will go into spin mode. Hope this helps!
