Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
The seal has softened so that the float assembly has gone down over the seal and valve seat. You need to buy a new seal for Mansfield 210/211 flush valves and replace the old one. It must go in the top groove on the valve seat. It will turn around if properly installed. I think that chlorine in the tank softens the seal.
Don't push down on the handle when it is hard to flush. You will break it!! Remove the lid and lift the center float assembly by hand.
I had the same problem with the Mansfield flush valve ,it was hard to flush and i ended up
breaking the flush handle and had to replace it. If the toilet is leaking ,you need to replace
the flush assembly or just the orange seal , mine wasn't leaking , so what i did i applied
some automotive grease to the flush valve seal . It is now easy to flush again.
Any automotive grease will do. Hope this helps
Put some automotive grease,any grease will do to the flush assembly seal, look mom no
more sticking valve assembly!
Hi im Rossouw
Take the lid of the cystern of and try to c were the arm inside the cystern gose that cums from the flush button. It will end at the flush meganisem that is 90% of time in senter of cystern. look if the flush meganisem is being pulled scew by the arm of the flush button. if so thast exstend the flush arm and it will be easy to flush the toilet.
Hope that helps uderwise thast replace the insides of the cystern, not that exspensive
plz rate my advice thanx
Toilet handle is hard to push down
