LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Posted on Jun 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker stopped working
We purchased this refrig in Dec 07. I noticed that the ice maker stopped producing ice about a week ago. I turned it off and then on again and one row of ice was produced and it stopped working again. Any suggestions?
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Sep 30, 2010
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10837955
Points
101584
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
jkkjffkj
2answers
Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
1helpful
Ice maker isn't making ice...
there appears to be a problem with 1. the temperature needs to be turned down to produce Ice. also is the fill tube frozen where the water goes into the ice maker sometime you have to thaw it to get the ice out of it and the reset the maker too. Let me know if this helped and if it did not don't rate and ask another question from me and I'll be galad to help. If it did would you please rate this solution please. Thanks for using FixYa.
1helpful
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
1helpful
2answers
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
2answers
Hotpoint Ice Maker Stopped Making Ice
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
1helpful
2answers
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
35helpful
3answers
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
