This is not promised to work but a known hack for your model of DVD
player is...
Make sure the player is switched on, and is at the
Samsung logo
screen. Also check the tray is shut and that there's no
disc in the
player.
Now press the REPEAT button on the
remote, followed by a five digit
code. This code is different
depending on what region your player is
*currently* set to:
R1
- 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6
- 24462
So for example if you have an R2 player, press
REPEAT-3-8-7-6-7.
If you've done this correctly (and your player
is compatible with the
hack), you should see a number at the top
left corner of the screen
corresponding to the current region.
Now,
pressing any number from 1 to 6 will change to the corresponding
region.
Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to
open the tray, followed by Standby (or DVD
POWER) on the remote to
close it and put the player into Standby mode.
The next time you
turn your player on, the new region will be set.
Don't forget
that if you want to hack it again, you'll need to use a
different
code, as listed above. If it's currently set to region 9,
use the
code for the last *proper* region you set it to.
People have
reported a problem with the codes given however another was posted
(57538) try that one to!!
