Some of possiblle causes:
The heater has an open circuit.
The thermal fuse has blown.
The High-voltage PCB has a fault.
The DCNT PCB has a fault.
FIRST:
under service mode * 2 8 * :
COPIER-FUNCTION-CLEAR-ERR-OK
Turn off and on.
if that doesnt help replace fixing film assy.
Canon ir 400 eror E000000-0000
wat can i do
SOURCE: I have an error message - E000000-0000. What's up
Hi there
E000000-0000
E000 to E004 are all to do with the fixing unit.
It can be reset.
It has been known to be caused by noise on the mains supply so a filter might keep it away.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again.
You should now be in service mode.
Select COPIER and this will give you some options along the top.
Select FUNCTION.In the list select CLEAR.
From the next list select ERROR and press ok.
Then switch off machine and back on at the power socket.
If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to turn the machine into a cabbage.
Sorry I cant help you more than this, hope it works for you
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Im getting error e000000-0000
ok the Error code is to do with your fixing unit, you need to go into service and clear the error then reset machine should work again.
do a search for clearing fixing unit error code on your canon copier, wont be to hard to find
canon copier tech
