Question about Polaris Scrambler Men's Mountain Bike
How to remove a starter on a polaris scrambler 500 1999.
How to remove a starter on a polaris scrambler 500 some say to remove the cluch an cluch cover an the cluch belt... some say to remove the pull start cover. there r two bolts on the back side of the starter i can get the one out but not the other its lose but u can't get it out polaris scrambler 500 1999
    New Friend:
  • 130 Answers
I have found it is easiest to remove the clutch and back clutch cover, along with the recoil starter.
Posted on Jun 28, 2010
Anonymous
SOURCE:
Starter pull rope does not rewind spring broke how to tear down
How to Rewind Recoil Starter Spring Quick Fix This page also has videos explaining how to remove and replace the cover with recoil spring.
Sep 01, 2014 | Polaris Scrambler Men's Mountain Bike
Polaris troubleshooting
drive gears are worn loosening drive chain
Aug 26, 2014 | Polaris 2011 Scrambler 500 4x4
How Polaris SCRAMBLER is different from other products?
Polaris SCRAMBLER XP 850 is coming with new more powerful 850 EFI high output engine which makes it better than others. Its new aggressive sport styling and 12" of ground clearance gives an unbeatable riding experience to the rider. For more features, visit: http://www.polarisind.in/off-road-vehicles/scrambler-xp-850-h-o-atv-quad
Jul 25, 2014 | Polaris ATV
When i am installing my battery on my 97 polaris scrambler it keeps tryn to start the motor, but the key is off and not in the run position
hi. you need to replace your key switch or starter solenoid , they have most likely jammed or burnt/seized into the closed position .
*** be carefull and make sure your battery is dissconnected when doing this .
May 06, 2010 | Polaris ATV
I have a 2004 500 polaris scrambler and starter wont work makes no click or any sound battery is good lights work with key on.
This could be a few different things, we'll start out by having you check the starter circuit. Locate the starter relay near the battery. Follow the wire from the start button on the left handlebar to the relay, then disconnect it. Connect a length of wire (jumper wire) from the battery positive terminal to the relay in place of the disconnected start switch wire. The starter should crank the engine. Other things to check are Battery voltage could be low ( lights and everything can still work) engin kill switch is off or defective, starter solonoid faulty, starter switch not connecting,Ignition switch defective, or the easiest fix a blown fuse. Hopefully this helped.
Mar 20, 2010 | Polaris ATV
Helping a friend,where is the starter?Don't want to take off something that doesn't need to be taken off. 2001 polaris scrambler 400 4x4
<br /> <br /> sadly enough there is alot to do to get to the bolts easily<br /> <br /> <ol> <li>take off pullstart not the front few bolts that hold the cord but the ones on the case behind those.<br /></li> <li>you will now see 2 bolts under the flywheel to the bottom those are the front starter bolts.<br /></li> <li>Take off clutch cover and clutches (may be able to get away with just the front clutch) and you will see the rear starter bolts.</li></ol>
Mar 12, 2010 | Polaris ATV
500 polaris scrambler won't shift into gear. the
broken shiift fork and or engagement dog
Jan 21, 2010 | Polaris ATV
Kickstart return spring on a 2002 Polaris Scrambler 90
You should be able to replace the spring by removing the side case
Jun 08, 2009 | 2002 Victory V 92 C
Polaris Scrambler Men's Mountain Bike  Logo
926 people viewed this question
Top Polaris Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Polaris Cycling Expert? Answer questions, earn points and help others
