Whirlpool dryer model LT7000XUN0 STOCK #LT7000V SEMC4119383 DOES NOT GET HOT TO DRY CLOTHER ONLY COOL AIR IN THE DRYER.
Check your heating element!!!
Testimonial: "no help at all."
There could be a fuse somewhere. Unplug your dryer. If you can remove the metal panel ling under the main dryer door to expose the heating element, usually located under the tumbler cage. Check the electrical that they are not loose, or that there is no discolored or shorted wiring. If this is the case, you should have professional repair performed before further use. of the dryer. The fuse might be located on the back side of the dryer. Where? I'm not sure, however fuses can be pretty rare on washers and dryers.
is there a fuse in the dryer somewhere that we could check? How do we check the heating unit?
