I have the same problem exactly please send me the solution with confirmation of the exact part requested
my machine is HOOVER HNL3137 1300rpm/7kg
thanks
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop.
for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
