Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Jun 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the difference between light and normal wash?
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 289 Answers
  • Posted on Jun 29, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
289
Questions
Helped
73830
Points
783
As I recall it is indicative of the load size. The "lighter the load, the less water it will use.
1helpful
Reduce time
you won't
most washers take an hour to wash a load
if you have a setting for low water and a light wash ,you might it down to 40 minutes
2answers
Light flahing
will have to repair the circuit board as something is faulty in the board.
it will not be too costly as the lights are flashing and that means only something is short.
thanks.
What does the Acela-wash button do? Why when you select normal or heavy duty cycle the Acela-wash light is on and you can't select other options
Kenmore elite 41072 vs. 41583? Opinions/experience?
ths.gardenweb.com > Home Forums > Laundry Room
Dec 30, 2014 - It is an LG 5.2 cu ft with a different dashboard e.g. Acela wash ... Dideither one of you get the Sears maintenance agreements(warranty)?
Electrolux 70 series....where's Larsi - Home Forums
Jan 8, 2015 - Larsi I know you have one so did you do a review on it that Im missing?... to run a load on Normal/Casual, Acela Wash enabled by default and Steam. ... the temp of the wash by pushing the water temp button while washing?
1helpful
Can't select wash cycles
Is the control board displaying any fault codes?
Try disconnecting the power cord to the washer from the wall outlet for 5 maybe 10 minutes...give the control board enough time to power down and hopefully the control board could self-correct itself by resetting. No different than re-booting a computer.
If you still run into the same problem, and if so equipped, try holding down the "end of cycle" signal button for 10 seconds and see if that resets it.
Why does all my lights flash in sequence on my Tricity Bendix washing machine
That actually looks like a normal system self test procedure the machine runs through in order to check everything is ok before the cycle commences. If however the machine was to stop part way through a cycle and display a sequence of different lights that sequence would indicate to the repairer what the computer determined to be the fault.
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
1helpful
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
