Question about Splendide 2000S Front Load Washer / Dryer
Splendide 2000 Model Help Needed
I need to find an electrical diagram for the Splendide 2000 model number WD802 - NOT 802M model. Bought the unit on Ebay - advertised as never used - seems new - looks new even on the inside after removing cover and back - hooked it up - unit fills with water - then nothing...need to troubleshoot the problem
    New Friend:
I have the same problem with my WD802 "pre M". I have found this forum and it as helped me some. Here is one forum that might help you - http://applianceguru.com/forum2/17215.html - I think it's my control module, but I cannot find a test guide for my "pre M" WD802 module. I am Calling Splendide first thing tuesday to see if they have a tech manual for the "Pre M" models. Good luck with your WD802.
Posted on Jul 03, 2010
6ya staff
SOURCE:
14802042 splendine 2000s door handle - Splendide 2000S Vented Washer/Dryer
that model number doesn't show up go here and look it up with the full model number off of machine
https://www.searspartsdirect.com/model/search.html?q=14802042
Nov 10, 2017 | Splendide Washing Machines
Where to finde front door handle
This is the information taken from the Splendide website. Hope it helps.
Westland Sales - Splendide Service Headquarters in Clackamas, OR Telephone:
Direct Fax:
E-mail:
Hours: 1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
*To help us serve you better, please have the Model & Serial Number of your machine ready when you call. The Serial Number is located on the inside door opening of your machine.
Jul 26, 2014 | Ariston Technologies AWD 121
Electrics
Can you first locate your model number? If I am unable to help you then someone will use the model number and be able to look your model up and refer you to diagrams and advice. There are thousands of refrigerators and millions of different wiring diagrams. I am here almost daily to help out people with appliance problems but when I see a refrigerator with no model number listed I just have no way to recall the needed information to assist people. I will post a photo showing the most likely location of your model number and if possible then you send the model number to me or whoever sees your model number will be able to assist you. If you need to contact me you can do so by clicking HERE
6_28_2012_11_16_55_pm.jpgThanks, Sea Breeze
Jun 28, 2012 | Refrigerators
I need a wiring diagram for a Splendide Washer-Dryer machine, model WD2000 S. Someone can help ?
Just finished fixing mine. Found a broken wire at one of the high temp limits. Found tech service manual at Splendide,.com/service/TECHMANXC. It's a pdf file that will walk you through any repair.
Nov 03, 2010 | Splendide 2100 Vented Washer-Dryer
Remington 10" elec pole saw diagram needed
Your IPB follows (we are prohibited from contacting you directly):
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
All Remington OMs and IPBs:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Be gentle with it, they are no longer in production, some parts cannot be found.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 21, 2010 | Remington Polesaw Wizard
Where can I find parts for the Splendite Washer/Dryer unit model WD2100
westland sales splendide parts ordering and tech support 800 356-0766
Mar 13, 2010 | Splendide 2100 Vented Washer-Dryer
Washer heating element????
thats a rather clever machine ..it uses cold water to condense the steam created in the drying process .. so there is no "wet" air exhausted into the room (no external vent needed) .. alas it does not have a "water" heater built in .. just an air heater for drying .. so you would have to use a detergent designed for cold water in your case ... make sure you clean the drain filter often in that model ..
Aug 17, 2009 | Splendide 2100 Vented Washer-Dryer
Hello, our handle broke off. who can we get to fix it?
record your model number off of the unit and go to www.searspartsdirect.com where you can order the part needed and install it yourself. Otherwise, if you'd feel more comfortable with certified repair, call A&E Factory Service, or www.aefactoryservice.com.
Jun 25, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Age of splendide 2000, wd802m
www.splendide.com
503-722-9202
Either of these could tell you about your specific unit.
May 01, 2009 | Splendide 2000S Front Load Washer / Dryer
Splendide 2000S Front Load Washer / Dryer Logo
657 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Ekse
peter gittos
peter gittos
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
