Symantec Norton Ghost 14.0: Windows Logo
Posted on Jun 29, 2010
I cannot get ghost to load the HP P6280T Realtek PCIe GBE driver. I believe I need to get another driver to work with this card.
I need to flash my bios, AMIBIOS, can you tell me where to find te last bios for this motherboard ? Thx Benoit
if a more recent BIOS version than yours is available, you should be able to find it here, along with instructions.
Usb3.0 aansluiten op moederboard
Hello here is the homepage, for downloading the manual:
http://www.msi.com/product/mb/760GM-P23--FX-.html#/?div=Manual
Please unzip the file, when downloaded.
You will need adobe reader, to read the content.
The usb connection is the small slot, just below the graphic card socket:
You will need a add in usb 3,0 card:
They exist with 2 or 4 outlets.
Good luck
2helpful
Internet only in safe mode
As you can still get Internet thru the safe mode then on google type REALTEK PCIE GBE FAMILY CONTROLLER open that page. Click on the link with Download Driver PC Pistop/ Library/ Realtek PCIE GBE family controller. Next choose your windows version and the right click Download. Give your email Adress and click ok, go to your mails and confirm by clicking on download link. The driver will be installed and system will restart. Here your Internet must be working normal without safe mode.
1helpful
Need ethernet controller driver for Zotac mini computer/with XP64 bit OS
Download from Realtek PCIE GBE family controller pc pistop driver library fom google search. Here you will be helped
1helpful
I have an HP p6217. My speakers have suddenly stopped working. I have changed the speakers, downloaded the driver update but still the speakers do not work. do I need to get a new sound card. Which sound...
If I have your correct model, you have Realtek ALC888s High Def for sound you can download here:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
This is your board:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01324212&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=4006038#N278
There is no reason your sound shouldn't work unless something is really wrong. Get into "device manager" and check the box next to "sound, audio and game controllers". If you see a warning, ?, !, or a yellow triangle, click on that and follow proceedure. You should have a list of your device(s) showing at this point. Right click on each one, one at a time and, you should see, in the list, "disable", if you see "enable", click on that. You should also see :this device is working properly".
You should have a speaker icon in the taskbar, lower right of your screen. Right click on that, then on "open sound mixer", and adjust your volume. You have PCIe, PCIe x 1 and, PCIe x 16 slots so, you could upgrade to a sound and/or a graphics card. Let me know if I can help you further.
Dave
3helpful
Hello while installing Lan Drives we are getting following errors. 'Please shut down and plug realtek PCIE card to complete the Installation" We could not able to resolve this .Can any one...
Drivers guide it seems that most mercury boards have the C39 lan drivers . So I believe it is the first C39 email me if so cause a lot of people need this http://exehub.com/msi-790gx-g65ms-7576motherboard-drivers-and-specs/
Cannot get sound to work
Asus motherboard P4V8X-MX
2answers
Need audio driver for windows xp for compaq SR5350F
The HP website may only have Vista drivers, but the FORUMS on the HP website have your solution right here.
Jan 3, 2008 18:55:05 GMT Unassigned Chipset Intel 945GC
http://www.intel.com/support/chipsets/sb/CS-020683.htm
LAN Realtek RTL8101E
http://tinyurl.com/2pgw87
audio Realtek ALC888
http://tinyurl.com/pfw3c
OR
load UAA first (KB888111):
http://tinyurl.com/2p5u57
then:
http://tinyurl.com/yl8m88
Original HP Multimedia Keyboard/Mouse Drivers
http://tinyurl.com/yubdjs
PC homepage:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3644737&lc=en&cc=us&dlc=en&lang=en&cc=us
Rich
say thanks with HP POINTS
2helpful
Echnical Information PCI Drivers and Utilities PCI Express Drivers and Utilities Problem caused by Realtek 8101/8168/8169 PCI/PCIe Adapter Driver (RTLH86.SYS) This problem was caused by Realtek...
Hi! Think you have installed adriver not recommended to be used with your pc. Try installing a diffrent version. You can download it from the link--
If it doesn't work go to bios settings when your PC boots by pressing F2 key. Then go to Advanced options and change the value of
Onboard Serial Port 1 : Option should be set to 3F8/IRQ4 .
Onboard Serial Port 2 : Set this to 2F8/IRQ3
Onboard AC97 Audio Controller: Enabled
Thanks
Rylee
Top Symantec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
