How do I send an external incoming call to an internal voice mail box instead of ringing the internal extension? When an external call comes in and the person they want doesn't want to answer, how can I just send it to the voice mail without having to tell my co-worker (the person on the internal line) to just not pick up the next time it rings (since I only know to go back to the incoming call that is on hold and transfer it through and have my co-worker ignore the ringing)?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
Try going in to you setting and look through them you may have put the call divert to voice mail on . if you have you can unclick it and take it off and that may sort the problem if your stuck ask you service provider to talk you through the steps
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
if you diverted to voice mail send #21# to deactive all diverts
if your answering machine is on turn it off
setting > application setings > call > all calls > answering machine > activation > off
Hi, what do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER) **SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING (CICS AND ICS 2.0+) **ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator) **BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+) **SET NORSTAR SET PROFILE **LINE NORSTAR LINE PROFILE **USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+) **TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+) *0 BUTTON INQUIRY *1 FEATURE KEY EXTERNAL AUTODIAL *2 FEATURE KEY INTERNAL AUTODIAL *3 FEATURE KEY PROGRAMMING *4 PERSONNEL SPEED DIAL *501 SELECT ENGLISH *502 SELECT FRENCH *503 SELECT SPANISH *6 RING TYPE *7 DISPLAY CONTRAST ADJUST *80 RING VOLUME ADJUST *81 MOVE LINE KEYS *82 DIAL MODES *831 AA ON/OFF (CICS) *832 CCR ON/OFF (CICS) *833 AA/CCR RECORDING MAINTENANCE (CICS) *84 AUTO LOG OPTIONS *85 CALL LOG PASSWORD *89 PROGRAMMED RELEASE *9 RUN/STOP 0 SYSTEM SPEED DIAL 1 SEND MESSAGE #1 SEND MESSAGE CANCEL 2 RING AGAIN #2 RING AGAIN CANCEL 3 CONFERENCE / TRANSFER #3 CONFERENCE SPLIT 4 CALL FORWARD #4 CALL FORWARD CANCEL 5 LAST NUMBER REDIAL 60 PAGE GENERAL 61X PAGE INTERNAL ZONE (1-6) 62 PAGE EXTERNAL 63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL 64 LINE POOLS 65 MESSAGE REPLY #65 MESSAGE REPLY CANCEL 66 VOICE CALL 67 SAVED NUMBER 68 RESTRICTION /COS OVERRIDE 69 PRIORITY CALL 70 CALL TRANSFER (BLIND) 71 LINK (HOOK FLASH) 72 TIMED RELEASE 74 CALL PARK 75 GROUP CALL PICKUP 76 DIRECTED CALL PICKUP 77 CALL DURATION TIMER 78 PAUSE 79 EXCLUSIVE HOLD 800 TRUNK ANSWER 801 CALL QUEUING 802 GROUP LISTENING 803 SHOW TIME 804 WAIT FOR DIAL TONE 805 TEST SETS (2.0) 806 HIDE DISPLAY 808 LONG TONES 810 MAKE BUSY 811 CALL INFORMATION 812 ENTER CALL LOG 813 LOG IT 815 AUTO BUMPING 817 IRAD TRANSFER (CICS ONLY) 819 OUTGOING NAME AND NUMBER BLOCKING (4.1) #819 CANCEL OUTGOING NAME AND NUMBER BLOCKING 82 CAMP ON 83 PRIVACY CONTROL 84 LINE REDIRECTON #84 CANCEL LINE REDIRECTION 85 DO NOT DISTURB #85 CANCEL DO NOT DISTURB 86 BACK GROUND MUSIC #86 CANCEL BACKGROUND MUSIC 87 "SERVICE MODES (DR-3,4,5)" #87 CANCEL SERVICE MODES 870 SHOW SERVICE MODES (CICS) 871 EXTENDED RINGING (ICS) #871 CANCEL EXTENDED RINGING 872 ALTERNATIVE RESTRICTIONS #872 CANCEL ALTERNATIVE RESTRICTIONS 873 ALTERNATIVE ROUTING #873 CANCEL ALTERNATIVE ROUTING 88 VOICE CALL DENY #88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS: "VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC." THE FOLLOWING ARE SOME COMMON USAGES: 9** "RAD PROGRAMMING (RAD 2, FASTRAD)" 9*0 RAD TRANSFER (ALL BUT CICS IRAD'S) 9*1 CHECK FEATURE CODES FOR VOICE MAIL 9*2 SMDR Admin 9*3 LOGGER TIME STAMP 9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9) 9*4 NORSTAR DOOR PHONE PROGRAMMING 9*5 FLASH LOW RANGE CHECK FEATURE CODES 9*7 ACD ADMIN MAINTENANCE SESSION 9*9 VOICE MAIL INTERFACE (VMI) CODES 900 SMDR,enter an account number to be logged with the call 901 ACD LOGIN 901 VMI Admin 902 ACD UNAVAILABLE 903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE) 903 ACD CANCEL WRAP 904 ACD HELP 904 FLASH ACD LOW RANGE LOGIN/OUT 905 ACD CATEGORIZE 905 FLASH LOW RANGE DN IDENTIFIER 906 ACD RECORD CALL 906 FLASH LOW RANGE VM TRANSFER 907 FLASH LOW RANGE VM INTERRUPT 908 STAR TEXT (OBSOLETE) 908 FLASH ACD LOW RANGE BUSY MODE 909 ACD ANN. MAINTENANCE 909 FLASH ACD LOW RANGE QUEUE STATUS 910 FLASH LOW RANGE LEAVE MESSAGE 911 FLASH LOW RANGE OPEN MAILBOX 912 FLASH LOW RANGE OPERATOR CONTROL 913 ACD CALLS QUEUED 913 FLASH LOW RANGE SYSTEM ADMIN LOGIN 915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2) 920 ACD ADMIN SESSION 921 ACD ROUTING SESSION DAY/NIGHT 922 ACD ADMIN STATISTICS SESSION 923 ACD GROUP STATISTICS SESSION 960 DIAL BY NAME (CINTECH NSVM OPTION) 961 DIAL BY NAME ADMIN (PSWD=1234) 980 VM SEND MSG TO ANOTHER MAILBOX 981 VM LOG INT MAILBOX 982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867)) 983 VM ADMIN PROGRAMMING (PSWD=1020000) 983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9) 984 VM TIME AND DATE(STARTALK Pswd=1020000) 984 AUTO FOREWARD TO VMAIL(NSVM4.0) 984 FLASH ACD LOGIN/OUT 985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)" 986 VOICE MAIL TRANSFER 987 VOICE MAIL INTERRUPT 988 VOICE ACTIVATED NAME DIALING (NSVM 4.0) 988 FLASH ACD BUSY MODE 989 RECORD CALL (NSVM 4.0) 989 FLASH ACD QUEUE STATUS
When you say voice mail, do you mean your personal vmail box or the AutoAttendant? If so you'll need to login to the 998 mailbox and modify the "Custom Service" prompts (menu# 5-3). NOw as far as the ringing goes, you might try doing an extension data clear procedure by doing Intercom -> *790 (I think it's Intercom 7900 on the older systems). Otherwise you should call a local Panasonic Dealer for a service call. Contact me offline for a referral.
Press dataregistration,press arrow up or down untill RX settings is display press start,press arrows untill incomming ring is displayed press start,set to on,next the amount of rings will apear on screen,change it there to the amount of rings.
What do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
if you have voice mail, you can set the number of rings before forwarding to voice mail in the administrative options of the voice mail menu itself. Call your voicemail and listen for administrative options. Follow the prompts.
