Sony KDS-R50XBR1 50" HDTV Logo
Anonymous Posted on Jun 29, 2010
Four blinking lights from standby led lamp after I turned on the TV.
  • Anonymous Jul 01, 2010
    It is not the lamp. I am positive
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jul 24, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957479
Points
33084
Yeah, it is not lamp problem. Check fans in tv as one of fan is stopped for some reason and causing problem.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1666
Points
5
Standby button(grn) is flashing when tv is turned on than red lamp light flashes.....what is it??
Chi Chu
Level 3:
  • Sony Master 8,457 Answers
  • Posted on Jun 29, 2010
Chi Chu
Sony Master
Level 3:
Answers
8457
Questions
0
Helped
2822967
Points
26282
The tv LED lamp life span is over.Replaced the lamp ur tv should work again.
tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
Hitachi UltraVision Tv Keeps turning off. The lamp LED blinks. Both light engine and lamp are new.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
google.com/+GopakumarGopalan
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
My Sony KDF-50WE655 does not turn on. Only the standby LED Flashes several times and then goes steady green, but the lamp light remains off.
Hello
You just count the number of blinks of the standby light before it goes out to green. In sony sets this blinking count ic critical for us to locate the faulty stage. You just count it after switch it Off by Power switch and Switch it On by the power switch at the front of the TV, for at least three or four times, and make sure abut the number of blinks, and report it to me. Ok
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
1helpful
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
My Sony HD-TV KDF-50E2000 blinks 15 times pwr button then turns on. After about 2 hrs turns itself off and blinks 40 times then turns itself back on. shorter and shorter on time thoughout the day. No led...
Symptom shows Lamp is getting weak and its time for new Lamp in TV.
Lamp replacement procedure is written in user manual.
Please buy Sony original lamp for TV safety.
Thanks.
1helpful
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
