I have a zhone modem 6218-12-200 and cannot get access to the log in page from where I would enter user name and password to check settings.I need to enable security settings which I know how to do but cannot get into the modem
.I type 192.168.1.1 and get "problem loading page"
Try doing a Google search USUALLY the address is 192.168.1.1 if your running xp or higher look for the command prompt icon it is in the start menu under acessorys the type ipconfig it should give you a number for your gateway or call up the manufatures tech support
A
wireless network is comprised of a wireless router, a computer (or
other wireless-enabled devices), a high-speed modem, and a subscription
to an Internet Service Provider (ISP). Netgear is a popular
manufacturer of wireless networking hardware that allows users to set
up a secured wireless network. In order to prevent unauthorized users
from logging onto your wireless network to gain access the Internet,
and in order to protect the data you transmit and receive online, you
should change your wireless router's security settings to create a
1 Install the router. To install a Netgear wireless router, use an Ethernet cable to connect the router to the cable/DSL modem and use another Ethernet cable to connect the router to your computer. Make sure all of these devices are powered off as you connect them. Once connected, turn on the cable/DSL modem, the router, then the computer, in that order. Allow at least two minutes to pass after turning on each device to give the devices time to recognize one another
2 Log in to the router. Open a web browser and type in the router's address to load the router's settings page. The router's address can be found in the user guide or setup CD that came with your router, or you can download a user guide from Netgear's technical support page (see Resources). Most Netgear routers use one of the following addresses: http://192.168.1.1; http://www.routerlogin.net; or http://www.routerlogin.com. Press "Enter" or click "Go" in your web browser after you have entered the address.
3 Enter the router's username and password. A prompt will appear on the screen when you enter your router's address, requiring you to enter a username and password before you can access the router's settings page. The default username for Netgear routers is "username" and the password is "password." Because the textboxes are case-sensitive, you must enter both of these using all lowercase letters. Press "Enter" to log in to the router and begin changing its security settings.
4 Open the security settings menu. The router's home page has multiple links for changing settings. Find and click the "Security Settings" link to change the router's security settings.
5 Change the SSID, choose an encryption setting and create a password. The default name (or "SSID") of your wireless network will be "NETGEAR." Enter a new, memorable name for your wireless network to help detract would-be hackers from trying to access your router, as most novice computer users with unsecure networks do not know how to change the default network name or institute any other security features. Newer Netgear routers offer WPA or WPA-PSK encryption to secure your network, both of which provide high levels of security. Select either of these. encryption types and create a unique password. This will require all users to enter the password before they can log in to your wireless network. It is important that you create a complex password that has several characters, including numbers. Once you have created a password, click "Confirm Password" to save it. To exit the security settings menu and log off of the router, click "Save" or "Apply" to save the changes you made, then click "Logout" to exit the route
Things You'll Need
* Netgear wireless router
* High-speed Internet service provider (e.g., Comcast, AT&T, Insight)
* Cable/DSL modem
* 2 Ethernet cables
* Computer
* Web browser
* Router address
* Router's username and password
Good Luck : ) ....
To configure your router, make sure you are connected to it first, open your web browser. Ignore any error about lacking a connection. Type the default IP address (192.168.1.1) into the Location field of your browser and press the Enter key. The following screen appears.
The default user name is Admin and the password is Admin. Both are case-sensitive.
Note: You should have your PCs configured for DHCP mode (if your router will be), and have proxies disabled on your browser. If you see a login redirection screen when you access the web interface, verify that JavaScript support is enabled in your browser. Also, if you do not get the screen shown above, you may need to delete your temporary Internet files.
The first screen that appears after the log in screen is the Home page.
From this screen you can configure the LAN and WAN connections, configure the router's security, routing, and filtering, access debugging tools, obtain the status of the router, and view the online help.
From here, go to the Setup Tab and click the New Connection on the left.
Input your numbers and don't forget to save.
Hope this helps!
