Cobra 29 LTD CB Radio Logo
Posted on Jun 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have weak talk back signal
I have a used cobra 29 ltd st cb. and i have changed mics off of it and put a mic off of a cobra 19 ultra 3 on it. they both have the CA-73 on the back of them. i can receive all kinds of signal but i cant talk backt to them and them beable to understand mem they say that its not very loud. my cables and antennas are all fine and the mic i just out on there off my ultra 3 all work, i could talk for a couple miles with the ultra 3 installed, but now with my 29 i cant talk back to them for them to understand. how do i fix this?
Anonymous
Level 3:
Guru:
  • Master 773 Answers
  • Posted on Sep 08, 2010
Anonymous
Master
Level 3:
Guru:
Answers
773
Questions
0
Helped
268915
Points
1659
Did you tune the antenna??
The antenna needs to be tuned for best SWR.
If the antenna is not the right length, then you will get signal reflecting back into the radio. this is bad and it can damage a radio.
The 29 has a built in SWR meter.
The lower the SWR the better.
Here is how to check the swr.
Turn to ch 20. Put the sf swr cap switch to CAL. Key the radio. With the radio keyed, turn the cal knob up until the meter is all the way to the right on the cal mark. with the radio still keyed, flip the switch to SWR. Where ever the needle falls is your swr reading. The top line is SWR. If it is above 3 this is really bad, and your antenna is no tuned and you are hurting your radio. You need to adjust the antenna length.
Turn to ch 1 and take an SWR reading the way I explained. Then do the same on ch 40. IF the SWR is lower on ch 1 then 40, your antenna is too short, make it longer. The antenna has a way of adjusting it. Usually the whip slides up or down in a colar.
If the swr is higher on ch 40 then 1, it is too long, and you need to make it shorter.
Keep making adjustments until the reading on 1 and 40 get lower, and are about the same.
Then check ch 20 again. It should be low, 1.5 or under. Then you are good to go.
you will find people hear you a lot better, way better then ever.
When do you know if you have a decent radio
The 29 has a built in SWR meter--check the match to make sure it is below 2 (lower the better).
The radio can be peaked for better than factory audio.
If the squelch is up too high you will not hear people below a certain signal level---in your case set it so you hear who you want to and not jokers.
RF gain lowers signal the radio sees for receive.
The stock mic will work but make your voice somewhat flat sounding---a power mic or having the mod limiter removed will make the radio and your voice louder.
Let me know if questions.
What mods can i do to my cobra 19?
tune up, swing mod, talkback, any thing that can be done to a cobra 25 ltd can be done to any 40ch cb.. just add a power mic$17.99 or a good echo mic will make a huge difference.
2helpful
2answers
4helpful
29 LTD CB Radio: whats the color to number wiring for cobra mic...
This is for a cobra CA50 mic
1-sheild
2-white
3-red
4-black
When I key the mic the needle on the meter does not move I have power to the radio and the mic is new
Try putting it on cb not pa,see if you hear other people talking,now try it.....could be the mike is not wired right,or bad meter..Put it on channel 19,ask for a radio check,if someone answer,s you its ok, maybe meter not adjusted...hope this helps..
My Cobra 29 LTD sometimes does not work even though the lights remain on. In other words I can't talk on it or hear anyone even though it appears to be operational
Your mic or mic jack is faulty. Try a different mic. In cobra 29's and some other variants, when you disconnect the mic, the audio is disabled. It will still receive, and transmit(possibly) but you will hear nothing from the radio.
It could be,
  • Broken wire on the back of the mic jack in the radio.
  • Broken wire in the mic cord.
  • Disconnected wires in the mic for the switch.
  • Dirty mic connection pins.
Most likely the problem is with the mic, and not the radio.
How to wire a power echo mic up theres 5 wires and 4 oins
I suggest buying a 5 pin to 4 pin adapter. Ebay has them for $6. I would go chopping wires on the mic. Cobra 29 ltd is a nice radio. Have one myself.
1helpful
NEED HELP WITH MIC WIRING FOR COBRA 25 LTD ST
1 Shield 2 White 3 Red 4 Black if the radio keys up as soon as you turn it on reverse 3 and 4 I am not familiar with that mic.But the way I actually should have given you the wiring order is as follows:1Shield 2 Modulation 3 and 4 key up I hope this helps.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
