Hi.
Regarding the phone line, see page 24-25 on document below.
Use RJ11 connector to connect the phone to Simon, then connect Simon to the landline.
This is the connection sheme:
To program the system you need to use the System Menu (see from page 40)
To enter the system menu, press either the scroll up/down or Enter buttons in the upper right of the panel. Press the STATUS button to exit a menu or option edit mode and navigate up one level. Pressing the STATUS button while in the top menu level exits the system menu level.
To enter system programming mode, do the following:
1. Press the scroll buttons until the panel displays System Programming.
2. Press Enter. The system prompts for an access code.
3. Enter the access code from the codes listed in Table 9. The system displays each entered access code digit as an asterisk.
4. Press Enter.
The panel is now in program mode.
For details on programming options see from page 42 (35 on page) in document here:Installation Manual
Here Key diagram.
Installation Manual
