Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Best way to unlock samsung e570 by unlock codes. you can get free samsung unlock codes for all samsung models at this blog.
there are many site which help you to unlock your mobile online but for that u need to pay some dollars to get unlock codes for samsung mobile..
You will need to take the phone to a mobile service center and have them unlock the phone for you.
Hi
you need unlock code to unlock you mobile,
you can get unlock code easily
Let me give you the Best site for getting unlockcodes
the pre sales was excellent even after thepurchase there customer support was a+, you can check them here.. Click Here............
SOURCE: whats the unlock code for samsung SGH E570, cause i cant use aps.
Try the following defaults:
1: 0000
2: 1234
3: 00000000000
4: 99999999999
5: last four digits of your cellphone number
One of these should work unless you or someone else customized the code.
Hope that helps
does my phone have a tracking device
