What kind of memory card? The DMC-TZ1 uses SD cards. If your card is larger than 2GB then it's actually an SDHC card. While an SDHC card will fit into an SD slot, it will not function.
If you are using an SD card, what happens when you try to format it in the camera?What kind of memory card? The DMC-TZ1 uses SD cards. If your card is larger than 2GB then it's actually an SDHC card. While an SDHC card will fit into an SD slot, it will not function.
You are right... it is a SDHC card. So, then I guess this 4 gig will not work.You are right... it is a SDHC card. So, then I guess this 4 gig will not work.
You can't post conmments that contain an email address.
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry. 2. If not OK, format the card in the camera. If that does not work, format it in the computer. 3. Try another memorycard and recheck.
Your camera is supported by: Memory card support : SD/MMC up to 2 Gigabyte. If you are using any other card your camera might give you an error message such as this one.
Try to format the memory card in my camera? NOTE this will delete all existing data on your card.
Do the following:
Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
Turn on the camera.
Press the Menu button, then go to the Setup Menu.
Scroll up or down to the Format option, then press the OK button
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Hi
In this case try formating the memory card. first put in the memory card to camera, turn on the camera and connect it ur computer. it will show up as removable disc under my computer. Right click on the removable disc and click on format. hopefully it should work.
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
