Http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the Manual and The Codes List!!
Enjoy!!
I need a code to enter on my telstar remote to program to a sony tv
Need codes for sanyo ht30744 tv
No it wasnt i need the codes for my rca universal remote.. how can i find them my remote is not working.. i need to watch my tv!!
I need the code for a sonicview receiver
I need a code for Telstar TV
I NEED CODES TO GO WITH MY RCR860 FOR VIZO TV
SOURCE: rca rcr860 remote manual code list
http://157.254.235.130/public/RCR860.pdf
These are the sites for the manual and Code List
SOURCE: I have a rca
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): We could not find an exact match, we think this code will work. 10054 Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
SOURCE: Need updated codes for RCA RCR860 remote control
If this is the post about the RCA remote and the Emerson TV, try 189. I have found the Emersons are NOT easy to program using universal remotes. I happened to stumble across the 189 code by accident and it works for the one Emerson (analog, 20" flatscreen) TV, but not an older model nor any of the Emerson VCRs that I used to won.
SOURCE: I NEED THE MANUAL TV CODES FOR THE RCA RCR860
Here is a link to the codes you need for your RCR860...
http://audiovox2.info/docs/rca_acc/man/RCR860_DOC_OTHER.PDF
SOURCE: Hello there I have just one more favor to ask. I
Hi, I don't see what you are trying to program but I'll give a link to get the manual for the remote.
Good luck, pls rate it :)
i need a code for orion tv
phillips
needs remote control codes for a phillip tv, RCA RCR860 Remote Control
got an rcr660 by rca...is there a code for a xbox 360?
Best Solution (and free) - http://bit.ly/15LLHC
Check it out!
Easy Solution for YOU -
Codes are here.
