Question about Microsoft Flybook V5 Tablet PC
T,h,y,5,6 keys on my keyboard don't work, have to use the on-screen keyboard
  • 3,917 Answers
Hi
Try compressed air to remove the dirt and dust underneath the keys. If it does not work then it’s a spyware issue, try downloading freeware program to find and eliminate it. Hope that will work.
laptop have a lot of various switches to turn stuff on or off if you press the right combo of keys try pressing you Fn function button down and try the keys that are not working .
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 03, 2010
  • aishe shuwa-tuggar Jul 03, 2010
    I have tried removing the dirt and dust underneath the keys with compressed air but they still don't work now I will try downloading freeware program to find and eliminate it. Will let you know.........thanks
Anonymous
SOURCE:
Why aren't detachable keyboard keys a/z/q working?
I can only guess but sounds like you need to buy a new keyboard .
Dec 30, 2015 | Tablets & eReaders
Disgo is frozen on home screen and home icon keep flashing i cant do anything
Search google to do a hard reset, I had the problem and after doing a hard reset it helped me and my tablet is working fine now. I don't really remember which keys it was but there are three keys to keep pressed and after that it will reset your tablet and if everything is ok it should work perfectly after that.
It would be nice if the manufacturer would also put that in the manual, because when I received my tablet I had to calibrate the screen and that didn't really help me. Also the tablet was working really slow and took a lot of time for everything, plus the fact that the keyboard kept pressing all sorts of other keys then that I wanted to press.
I hope this will help you and that your tablet will work fine for you.
Let me know if you had any success.
Sep 08, 2012 | Disgo Tablets & eReaders
How to activate/use external keyboard with tablet
Try this Coby-related post, which I found... Directly quoted:
"The tablet is setup so that whenever you will be using the keyboard you will have to set it up! So with the machine on and the keyboard plugged into the tablet you select "settings" on the main screen. On the next screen you will need to scroll down to "Advanced Settings". On the next screen you will scroll down to "USB BUS MODE" and deselect the button removing the green check mark. You then select the Curved arrow on the side above the silver button wich backs you back out to the main screen. Now whenerver you open a screen requiring key imput you will be able to use the keyboard."
Oct 24, 2011 | Coby Kyros 716829701508 Tablet PC
Both of shift key on my keyboard are always turn on..how to make it fix..?and i can't to restore the system..
i have the same problem.
I run the windows screen keyboard and i discovered that when i press both r+t keys and u+y both shifts are switching on. i'm not able to switch it off even using mouse on screen keyboard.
as temporary workaround i press fn key then i press shift on screen keyboard, then both shifts switches off.
i didn't fount full solution.
Jul 08, 2009 | Toshiba Tablets & eReaders
No keyboard instructions
You need to press the Function button, then the num lock button. The function button may be labeled FN or F in a different color, the same color as the num lock button.
If that doesn't work, go to start, all programs, accessories, accesibility, on screen keyboard....it will display a regular keyboard on your screen, then click on the num lock key on that keyboard.
May 24, 2009 | Compaq TC1100 (/) PENTIUM M 753 1.2GHZ...
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Jan 16, 2008 | Toshiba Portege M400-S5032X Tablet PC
Viewsonic Tablet PC keyboard issue.
may be the best solution for this problem is consult your hardware manufacturer and ask him to replace the motherboard, if the pc is under warranty they will replace it for free of cost.
Apr 05, 2007 | ViewSonic TPCV1250S (TPCV1250S0103) Tablet...
Microsoft Flybook V5 Tablet PC Logo
Top Microsoft Tablets & eReaders Experts
Ekse
Harrie
Ruben Caraballo
Ruben Caraballo
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
