Invicta Sea Spider Chronograph Polyurethane Stainless Steel Watch for Men Logo
Posted on Jul 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove pins to size an Invicta Sea Spider model #0140
Anonymous
Level 3:
Genius:
  • Master 1,970 Answers
  • Posted on Jul 03, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1970
Questions
0
Helped
847475
Points
4702
Mcdevito75 here, Aren"t the spring bars (pins) built into Invictas Strap?? Look on the back of the Strap real close to where ot attches to the watch, see a little tab you can move with your fimger, this tab should compress the spring bar (pin) and allow you to remove the strap.
Looking for band for invicta sea spider 1261..i want to replace it with a stainless steel band..
Sea Spider 1261 INVICTA Sea Spider Men 50mm Stainless Steel Gold Black dial 3600K Mechanical watch located attached link offers multiple compatible straps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jamie_580d75bd3bb6d659
How can i take the back off the invicta sea spider model no. 5915 so i can change the battery?
Hi I love my Invicta watches also. My wife is telling me that collection is close to how many shoes she has LOL. You will need a special tool the tool has two adjustable prongs so it will fit a Rolex and any other screw on type watch. Normally they come in a set of watch tools. I would suggest eBay, you can get a kit that not only will open any back on any watch but you will get tools for removing the pins in the band. There is also a unique tool to help you put the spring pin in that holds the band to the watch. One word of caution when searching on eBay look to see where the seller is. If it is China I would find one here in the States. I hope this will help you
Have a great day.
MgySgt Shirel USMC (retired)
1helpful
How do I remove links from a Invicta 0132 wildflower watch?
You need to remove the push in pins. Use a small pin or dull needle that fits the holes size. Push on the pins to remove and push them back in to reconnect. They can be in fairly tight so be careful. It can also be hard to push them back in as well. They usually only go in one way, just in case, pay attention to how they are oriented when you remove the, so they go back in the same way. See image attached. Remove as many links as you need, to get the size you want.
How to remove links from invicta sea spider polyurethane bracelet
You should use two extremely small flat head screw drivers to remove links on Invicta polyurethane watch bands. The smaller pens on the polyurethane watch bands have a notched cap (tiny screws) on each end .You must use one screw driver to hold the pen cap (screw) steady and the other screw driver to turn the cap (screw) counter clockwise. You only have to remove one notched cap (screw). These caps (screws) are very small and you should be careful not to lose them. Once you removed the cap (screws) you can use a small screw driver or paper clip to push the pens through the links. You should repeat this til you remove the desired links.
Adjust bracelet on sea spider?
Thank you for contacting FIxYa.<br /> I suggest you take your watch to a reputable local jeweler for sizing. Expect to pay a nominal fee (around $5) for this service. Do not attempt to size your own watch! You may damage or scratch the watch and bracelet. The liability is yours.<br /> If you still decide to do, follow instructions given here:<br /> <a href="http://www.webwatches.co.uk/how_to.htm" target="_blank">http://www.webwatches.co.uk/how_to.htm</a><br /> Best wishes. Jewel
6helpful
Adjust the band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove watch bracelet links. Rate me, please
Top Invicta Watches Experts
Ngoro
john h
Are you an Invicta Watch Expert? Answer questions, earn points and help others
