The best way to fix PS3 turn off of it's own and show red light flashing is to fix by yourself! Learn the PS3 fixing technique by using this product here :
PS3 Ultimate Fixing Guide
This is a package of text and video tutorials written by a professional PS3 repairman. Follow his demo you can easily to unscrew your console and fix parts inside. When you have learned the repair skills, no need to ask anyone here again!
Yes this is the red light problem you have 2 choices to fix it:
1. send it in and they will repair it for you.
2. Use a good guide to fix this from home.
SOURCE: flashing red light, turns on
hi, the problem you are having is due to the ps3 over heating, if you have any warranty on it then take it back and get it exchanged, you wont be able to get the game out without it working or without taking the dvd drive apart.
to fix the ps3 your going to need to have the gpu and cpu chips heated up using a reflow station as the problem your having is with the solder on these chips what happens is when it over heats the solder cracks and you lose the connection with the circuit board so you need to get the solder reflowed to create a circuit again, its not something you can do yourself as you need special equipment to have it reflowed,
i do these repairs myself so now how difficult it is to get it right, shop around and see what price you can get, the actual problem you have got is called yellow light of death its called this as the red light flashes yellow just before it flashed red, it is worth getting fixed so shop around and see what price you can get.
if you have any warranty left then this is covered im sure sony cover this fault under warranty for 3 years but you will need to check this either by calling them or checking on their site.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts,
im sorry i couldnt give you an easy fix but without taking it apart and reflowing the gpu and cpu chip their is just no way of getting it working again
