Your problem might be that a magnet has fallen off. Here's an illustrated guide that will make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
I have York T710 thats not working. Keeps coming up with error 1 code. Have gone through all the trouble shooting tips but nothing has worked. any ideas?
ERR
1 - Motor Movement
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs
from
the speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or
the
signal is not reaching the display.
Tes the s. sensor for open or faulty. Clean it + tight the connector very well and try again. see the diagram for adjust.
God bless you
ERR
1 - Motor Movement
ERR1
from
the speed setting.
Analysis:
the
Clean the sensor, test for open or faulty, tight the connector very well,adjust it, see the diagram attached.
God bless you
ERR1
from
the speed setting.
Analysis:
the
