ETR film counter resets mid roll when shutter is depressed.
Hello. 35mm cameras back in the day used to suffer from this irritating problem. There is a small button that is pressed by the door edge when you close the back. Due to age(flexing and slop) that occurs with normal wear, the metal edge becomes ever-so-slightly bent, resulting in a less-than-needed pressure on this button. The button, when held properly by the back, captures a little internal gear mounted on the film counter dial--preventing its spring-loaded return. When you remove the back to re-load film, the counter immediately jumps back to "start". As the film advances, the roll increases in size and pressure against the door, causing the symptom. Go to a camera store with knowledgeable sales people and you might find one who knows how to re-work the back just-so to fix it. To be absolutely sure, however, you'll need to buy another back.
On some medium-format cams, there is a little raised "bump" on the edge of the door that precisely matches up to the position of the button. If this is the case, and you are careful, it can be gently but firmly squeezed to make it stick out more, increasing the pressure on the counter button.---Rick
