Hi i have a hoover hsw 150 m washer dryer but i have no instruction booklet so i don't know which section in the drawer to put the washing powder and what section to put the fabric softener.
A lot of times the hose gets just clogged. What you do is get a tea pot, and boil some water. Then carefully pore some hot water slowly down the drawer, little by little until it breaks up the soap to unclog it. Another affective way is buy a can of air in a can. Compressed air in a can is used for many uses, such as cleaning a key board or lightly blowing out electronics, can get it at almost anywhere they sell computers. Then you do small burst of air in the detergent drawer. However I would try the hot water first, and save some hot water for a cup of tea as your patience of having it work. Thanks Mike
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
1 is usually for pre-wash, 2 for washing powder and fabric softner goes into the section with the level indicator should be small square section with removable top.
Here is the Hoover site where you can download an instruction manual. http://service.hoover.co.uk/manuals/?Section=2 I had no idea Hoover made washers, dryers, or combo units. They only sell vacuums on this side of the pond.
hi..the reason for this problem is the powder drawer
could have got struck.The pin that is attached to the
tray could have got strucked somewhere.u dont try to
pull it.please call your mechanic to do this job.
try this out..
thank u..
rate me..
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Hi. In you browser box type in Hoover user manual. Then scroll down to Hoover after sales service instruction manuals.. Click on this, and then on Laundry.then on Waher -dryers, follow instructions You will find your model listed there,. Please leave good feedback. Thanks
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
