Question about Roper REX3614KW Electric Dryer
Hi i have a roper electric dryer and it will go threw all the cycles but wont dry clothes like wont heat up
  • Roper Master
  • 43,501 Answers
Hi, If you have a gas dryerhi i have a roper electric dryer and it will go - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_notIf your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problehi i have a roper electric dryer and it will go - 2_bing.gif
Dryer Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
6ya staff
SOURCE:
Our dryer heats up but never dries the clothes, even after several cycles. and Im talking 5 times to get the clothes semi dry. all vents are clear and clean. what could be the problem?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 22, 2011 | Roper REX4634KQ Electric Dryer
It takes at least 2 cycles to dry clothes. It is Roper heavy duty high capacity electric dryer. Thank you for any help you can give me. janebellard@yahoo.com
Check for air restrictions which cause the heat control to shut down faster than normal.
When the moisture cannot be removed fast enough the heat builds up and has nowhere to go so the heat control stays off longer and the clothes just tumble on.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 14, 2011 | Roper Dryers
Neptune MDG5500AW Gas Dryer: What causes my dryer to dry clothes one cycle but ...
Believe it or not your ignitor is going bad...
If you have a gas dryer2_bing.gif.
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
May 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Jan 05, 2010 | Roper RES7646KQ Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer has some heat but is taking a long time to dry clothes
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
What would cause intermittant heating in a Roper Electric Home Dryer?
the dryer vent, not the parts behind the dryer, where it goes into the wall to where the vent leaves the house has lint build up in it. this will cause the element to short cycle cause long dry times. if its really bad ive seen people have to run dryer 3 or 4 times to get clothes dry. clean out vent. this should solve problem
Nov 20, 2007 | Roper REX3614KW Electric Dryer
Roper REX3614KW Electric Dryer Logo
160 people viewed this question
Top Roper Dryers Experts
Marvin
Marvin
Dennis Boxerman
Colin Stickland
Colin Stickland
Are you a Roper Dryer Expert? Answer questions, earn points and help others
