Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
Posted on Jan 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic 42'in viera no pic, just thick,square, white border
TV suddenly went off and a thick white, square shaped border appeared in middle of black wide screen... and nothing else....The tv is about 2 years old and never had a problem with it before...
Have turned off and on.. checked Virgin satellite box etc.. but nothing has worked!!
Help!!!!!!
R Daniel Wolfe
Level 3:
Master:
  • Master 469 Answers
  • Posted on Jan 04, 2018
R Daniel Wolfe
Master
Level 3:
Master:
Answers
469
Questions
0
Helped
103836
Points
1118
Unplug it, wait a minute and replug it. Also check the settings and see if it changed.
4 Related Answers
Anonymous
  • Posted on Oct 31, 2007
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
Anonymous
  • 10 Answers
  • Posted on Feb 02, 2009
SOURCE: plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
PanamanNE
  • 9 Answers
  • Posted on Aug 14, 2009
SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 06, 2010
SOURCE: hi, are tvs that are described as 42
That measurement, is measured on the DIAGONAL corner, to corner distance. It's NOT the actual measured width of the Viewing Screen. IT is only 1028mm Wide, but from corner to corner it's going to be..1070mm or 42 inches
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
1helpful
Can i challenge the color of the sidebars of mi plasma tv, from gray to black?
No you do not want black even if it could be changed which it cannot.
The problem with black (and why it is not used) is after prolonged use with a black border it will BURN that image into both sides of the screen unit--you will be able to see it.
1helpful
My Panasonic plasma TV has suddenly developed a one pixel thick horizontal black line across the screen. It is not there when the TV is switched off.
it'll not be there when tv off because dead pixels do only show when back light of screen comes on, anyway if you still have a warranty then ask for them to check it out as it sounds like you need a new screen there mate
I have a panasonic viera plasma and suddenly have a 1' black line going down my screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
On my tv screen I have a vertical white line with some colours
the x or y driver board is failing.best to have a servicer checked out
2helpful
2answers
Panasonic viera
3.Faulty cable.
Puzzler.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
