Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Probably a clutch issue se if this post will get you started Clutch Fix
If you are going to DIY you will need the Service Manual. You can't get it from servicematters.com anymore. There is another site that you can join and dowload the FAV6800A/FAV9800A Service Manual.
I'm sure it is a Clutch Malfunction if the wash tub is banging around in Spin Cycle of the Wash Cycle. See if this post Clutch Fix you will need the Service Manual, servicematers.com now charges for this but other forums have it available. Join this forum then download the SM16022808 Maytag Top Load Neptune Washer Service Manual
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed. Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
