My ge wsm2700dawww stack washer will not agitate or spin
My ge wsm2700dawww stack washer will fill and drain but will not agitate or spin. The belt is fine and the lid lock works fine. I am at a loss as to what to do next.
Re: my ge wsm2700dawww stack washer will not agitate or...
Hi
Please find the links bellow to diagnose your problem…since your problemto the washing machine can be caused due to various reasons.Please go through the article to have an in-depth knowledge to your query…
my ge washer model # wsm2700dawww, squeaks when it is agitating what could it be....HELPmy ge washer model # wsm2700dawww, squeaks when it is agitating what could it be....HELP
You can't post conmments that contain an email address.
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Inspect the drain hose for kinks Test the timer control Test the lid switch (some models) Inspect the water pump Inspect the drive belt (belt drive only) Inspect the motor coupler
The washer fills...sound like the motor is running but it doesn't agitate or spin.. then when it tries to drain it bascially gravity feeds out until there is no longer enough water to force it out?
Sounds like the belt is off, or broken.. I am not all that familiar with your model, but I think most GE's are belt drive.
If it were the agitator coupler, the washer would probably still drain..
Pull the front cover off of the washer, you will see the belt and pulleys, make sure it is A: still on the pulleys, and B: tight.
If not, loosen the four bolts on the moter, put the belt on and then slide the motor towards the rear to tighten it.. then tighten the four bolts. They may simply have not tightened the bolts on the motor from factory and the motor slid back loosening the drive belt.
