Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
