The board goes to a E1 code after 3 sec. The motor will never initially start up. If you remove the belt and simulate the motor running by moving the belt manually you can keep going because it does not error out. I can't get any information on the output voltage of the board so I can test it. They just want to sell the new $500 + dollar board.
My felax trademill starts counting to 3 , then nothing after then E1 will appear ,and
something it display E9, E4 , what to do just help me
Lets eliminate the motor first, unplug unit remove motor shroud fin the 2 leads from motor to lower board. Connect a 18v DC battery to the leads this start the motor to move at approx. 1 mph if it does motor is good,if not you may worn motor brushes worst case open connection in the motor.
Now if the motor is good then reconnection the leads and plug in unit the lower board should have some LEDs lit up. Now find the LED that says PWM start unit if that light should start to flicker then the upper board and wire harness are work properly. Turn off the treadmill then turn it on and with a multi meter insert the leads into the connectors that go to the motor, then put the meter on 200v DC then start the treadmill you should get a reading 5 to 10v DC if you get 0v DC then the board will need replacing
Here's an illustrated guide on how to fix it: http://fixmytreadmill.blogspot.com/2010/...
