Hi pillis_2y4,
The F1 error code description is a defective touch pad or clock (ERC). Here are some steps that you may apply to check if the ERC (Electronic Range Control or Clock) or the touch pad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker. It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back
7. Please replace the ERC, if F1 comes back. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
