Tomtom GO 720 GPS Receiver Logo
Anonymous Posted on Jul 08, 2010
How do I change language without resetting my receiver?
Have tried main menu>preferences> can't find change language.
Anonymous
Level 3:
  • Master 518 Answers
  • Posted on Jul 11, 2010
Anonymous
Master
Level 3:
Answers
518
Questions
0
Helped
130320
Points
1123
I have a tomtom go 730 iq routes and on mine tap the screen, press change preferences and then tap the arrow until change language appears, mine is in the top lefthand corner, hope this helps.
Testimonial: "Thank you.now all OK I am grateful for your very quick advice. Bryan"
1 Related Answer
Anonymous
  • 74 Answers
  • Posted on Dec 26, 2009
SOURCE: My Main menue language is German on my TomTom 130 GPS
In the menu, you should find the settings for language.
Now, If you don't speak German, this can be a problem.
If you use your computer to translate, you can do it.
Go to http://babelfish.yahoo.com/ and select the languages as required (German to English). Enter the commands you see on the TomTom, and navigate that was until you see the language settings.
How do I reset the garmin back to english.
To change the language, Main Menu > Settings (wrench & screwdriver icon) > arrow down to Language & Keyboard (lips icon) > Text Language (second selection) > select your choice.
Once the text is changed, go back and change the Voice language and the Keyboard language settings.
You will find a lot of Garmin help on Youtube
Jan 08, 2015 • Garmin GPS
3answers
My GPS TOM TOM has a forign language on it and I do not know how to change it to English. I have a TOMTOM GO 930. The written language is in Spanish. How do I change it to English?
This reset will delete all user settings: Favorites, Recent destinations, etc.
This option can be found under Main Menu > Change preferences > Reset factory settings.
If you do not have this menu option available, you will need to first select Show ALL menu options, located in the Change preferences menu
NOW!!
1. Once reset, turn your unit back on and you should eventually see the following screen. Tap in the lower-right corner to continue.
2. Tap in the center of the next screen to access the Main Menu.
3. Tap on the blue wrench icon to access Change preferences.
4. Tap on the right-arrow until you see the following Change language icon (designated by 3 flags). Tap on this icon.
5. Now simply tap on your language preference. You will be prompted to confirm your selection. Choose YES to confirm and NO to choose a different language
Aug 15, 2008 • GPS
2helpful
My tomtom 720 gps is back to factory setting. I need help resetting to English.
From the main menu screen, select "Change Preferences". Then look for (tap arrow at bottom) "Change Language" button. Tap the language (listed) and follow the instructions to confirm the language selection and choose a voice.
How to change language
It is normally done under 'Change preference' (look for Spanner image Icon) -> Scroll right Arrow until 'Change language' (look for Flags image Icon) -> Select --> Select an Voice
Just look for the graphic when you bring the menu up as it will be in whatever language!
Hope it helps: let me know how you go.
How do i change the langiage of my Tom Tom 720 Go ? i have tried resetting it but does not reset the language. Also how do i set my Home address please?
To change language:
See my other post on this subject: the steps are also applicable for your device.
http://www.fixya.com/support/t3818168-tomtom_130_apps_in_foriegn_language
Basically: 'Change preference' (look for Spanner image Icon) -> Scroll right Arrow until 'Change language' (look for Flags image Icon) -> Select English -> Select an English Voice
To set Home address:
''Change preferences' -> scroll right to get 'Change Home Location' -> use 'Adress' to enter new address or 'Recent destination' to select a recently entered 'navigate to' address. Hope it helps. Let me know how you go and good luck.
How do you change language? stuck on language i cannot read
It is normally done under 'Change preference' (look for Spanner image Icon) -> Scroll right Arrow until 'Change language' (look for Flags image Icon) -> Select English -> Select English Voice
just look for the graphic when you bring the menu up as t will be in whatever language!
1helpful
How do I change language on tom tom?
First, turn it on.
From the map screen, touch anywhere to get to the main menu.
From the main menu, touch Change Preferences.
Scroll through the Preferences screens until you reach Change Language (the icon is a bunch of national flags). Tap it, then choose your language.
2helpful
2answers
I want to change the language on my tomtom go 630 from afrikaans to english
To expand SQUIRESXXX's solution a bit:
From the main menu, tap Change Preferences.
Scroll through the screens until you reach Change Language (shown by a set of flags). Tap that icon, then select the language you want.
2answers
I need to change language from Italian to English
Try entering this into the phone *2767*3855# this is the master reset code so you will loss all your stuff but will reset back to english
6helpful
Tomtom in foreign language need english
on you main menu go to the wrench picture, that is change preferences. Then touch the arrow, above done on the screen 3 times til you reach the screen that has "3 flags flying. that is the icon to change language. touch that, choose english us and you're done.
i had the same problem. take care
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
