When you start it on a normal wash the machine fills then sounds like the water is draining out of the machine, then the rinse light flashes and the machine stops. I have tried it on different cycles, but still the same thing. Cleaned all the drains and drained the water out of the machine
SOURCE: washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
