Before trying to fix the iTunes error with some methods, you need to be sure you have the newest version of iTunes on the computer. Sometimes just updating to the newest version of iTunes is enough to resolve all syncing problems, particularly if the desktop software hasn't been updated in a while. You can always download the newest version of iTunes directly from Apple. After updating to the newest version of iTunes, if you find that your iPhone still won't sync with iTunes, you can follow the tips below to fix the error.
1. You can simply quit out of iTunes, then relaunch the app, and try syncing again. Sometimes this is enough to get your iTunes working again.
2. If syncing fails, the Sync button is greyed out and not available at all, or if you try to sync and nothing transfers over to the iPhone, iPod, or iPad, you may simply need to authorize the computer with iTunes.
3. You can also try restarting your phone by holding down the home button and power button.
4. Sometimes just restarting a Mac or PC is enough to resolve the problem and get things syncing again.
5. Typically use Wi-Fi Syncing? Try using a USB cable instead. Usually use a USB cable? Try using Wi-Fi syncing instead to see if that works.
6. If you find wireless sync to suddenly stop working, you typically just have to toggle the feature on and off again to get it functioning again.
7. Sometimes USB ports go bad, and though it's pretty rare it's very easy to rule out. All you need to do is switch the USB cable from one port to another and see if it works.
8. Reset and restore the iPhone. This should be your last option. You will lose all the data on your device. You will be resetting your phone to factory settings and start as if its a new phone. Only advantage is that you have iCloud backup.
For more details, check: How to Fix When iPhone Won't Sync with iTunes
SOURCE: OS 10.4.11 Won't Sync Calendars w/iPhone 3G
Make sure that in the sync settings you don't have Outlook turned on or something. If that is on, and you don't actually have anything to sync in outlook (or don't even have it), then this can result in it sitting for a long time, if not forever. You might also try to check and make sure that a dialog didnt pop up and somehow get minimized to the dock or something as well. I had a similar issue with my ipod touch and all it ended up being was a stupid check box under the calendars sync settings.
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
SOURCE: sync iphone 3g calendar w/outlook 2007
In itunes go to syncing options and make sure contacts and calender are selected! then resync! hope this helps! Merry christmas!
Where did you purchase your phone? however, you first need to update itunes to 8.0.2, that might solve your problem. Unless you have an unlocked phone then restoring your phone is useless because when you restore an iphone with itunes in the US without an att sim card it will actually lock the phone, but I do not think that is your issue. the two things you are seeing the connect to itunes and the emergency call system means that your phone is not properly activated. which is done by connecting it to itunes.
SOURCE: iTunes cant connect/recognise my iPhone 3G
Hi Try and plug your iphone to another pc and see if the same problem is still there, if no problem is form your pc, other wise you are having a problem whit your iphone i would advise to send your iphone to repair to www.E-Repairs.co.uk
