If your clock radio is like mine here is how it works:
Hold down the "Alarm Set Off/On."
While holding this button down, press on the "Hour" button until you get the time you want to wake up. Set the minutes the same way. Be careful- look at the red light to the left of the digital time to make sure it is lit up next to the " AM" spot just to the left (not digital, but usually on the radio metal or plastic itself.
Then let go of these buttons. Go to the right-hand side and slide the button to show if you want to be wakened by the radio or a buzzer. If you want to keep on that schedule, you don't need to do anything. Just move the button to "Off" the night before a day off so you can finally sleep in!
Hope this helps.
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
I doubt there is a way to change that, but it's also not clear which way it's supposed to go anyway. Mine projects "right side up" if you are facing the same direction as the clock is facing - that is imagine you are looking away from the face of the clock. It is upside down if you are looking at the clock's readout. One way to solve the problem would be for you to turn the wheel of the projector to make it face the opposite wall. It will then be right side up.
Hi. There should be a switch on top of the radio that allows you to select the time zone. It is just behind the snooze bar and labeled PST-MST-CST-EST. Try that.
