If you get Error 101 after a long wait (this means an actual update is being downloaded) - then to fix it, you need use "Run as Administrator", this is probably because the updater wants to change the contents of an executable file, which is a security risk. So Vista, by default, forbids this action and blocks the program continuing - this shows up as Error 101
When you "Run as Administrator", then the updater is given permission to change the executable so it should work.
How?
What do i do to solve the adventure rock problem 169
Delete it then redownload or run as administrator
Help me i got error 101
Error 156 keeps comeing up everytime i try to play! i think its rediculous as it took over half an our to download! it should work
Error 1 means that you don't have an internet connection. Try to look on the AR message boards on:
http://www.bbc.co.uk/dna/mbcbbc/F9558041
Meto i need help 101
Mine has come up with (Error: 1). Any help available? I cannot get through to AdventureRock Support either.
Can anyone come up with a solution
I had the same error but went to this webpage and downloaded the directx9.0c and no longer get the error
www.softwarepatch.com/windows/directx.html (don't click on the free registry check unless you want to!)
Need help with error 101 please
Hi buddy!
the error 101 is the fatal error one of the cause this error is the installation of operating system is not exactly complete or have a corrupt dynamic link library or DLL. and also this is cause of spyware.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
I downloaded adventure rock and clicked lauch adventure rock when it had finished dowloading then it said ERROR: 106
I had excatly the same problem - error 106! I've had a look at the properties and i can't seem to make it work! I'm not very good with computers and my daughter is DESPERATE to play on this game!
Can anybody help??
I NEED A FREE SERVICE TO FIX THIS PROBLEM.
101
I also have an error 'update process (error 101)' any ideas would be welcome...
similar problem here, but error 101
me to
me too!!!! 101
Me too
its so annoying i so want to play this new game and i have tried everything has annyone got any ideas??
i have upgraded active x and direct x and restarted the computer what else can i do?????
I have similar problem but it is error 101
I think its anoying we should be able to play any way I WILL COMPLAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
101 to
comes up with error 101
error 156 comes up on the updater
I HAVE THE SAME PROBLEM WITH ADVENTURE ROCK BUT A DIFFERENT ERROR (154). HELP ME!!
when i click on adventure rock it comes up with there is an error 106 and just freezes.
Exactly the same
Tries XP compat - no change
error 101 keeps coming up when loading adventure rock
error 106 help me
i have error 101 too
The same thing has happened to me and i can't get through to the supporter either. Nothing works!
hellllllllllllppppppppppppppp error 101 is driving me crazy
I've got Error:106 I have no idea what it is, can anyone help me? Would re-installing it be of any help? Or installing it from elsewhere?
The Loading Won't work
WHEN IT IS DOWNLOADING, IT STOPS AND SAIDS ERROR 101 AND PLEASE CONTACT ADVENTURE ROCK SUPPORT.
My grandson tried to download adventure rock, was going fine until the last bit, cant find helpful support, pls help.
same
i,m having troubles with error 101
its a pain and ive tried looking it up
yeah i have the same problemÂ
i download adv rock then as i start adv rock updater i get error 101 (a problem occured during update process) have tried re installing and system restore to no avail please help? any ideas
it says i got a error and i dont no why can you fix t?
when i run adventure rock it say there was an error eror 106 what should i do
I need help adventure rock does not work
My computor says exactly the same except it says error code 101
that happens to me but mi error code is 101
it goes through most of the download and then on the last blue bar it says you have error 101 please contact adventure rock adminstrators but i cant find them
i have got the 101 problem
someone help i have got error 106
same ere
i had eror 101 and i don't know what to do
when i run as admin it strts from the begining but i dont think it works, hang on.........
my thing wont work and my email adress is [email protected] so email me please.
I go to load AdventureRock but it says 'A problem has occured during the update process (Error:101) If the problem persists, please contact AdventureRock support.' What shall I do?
i cant get on coz of error 101 can anyone help me find adventure rock support. email is [email protected]. thanks
i have the same problem kasabian
I DOWNLOADED ADVENTURE ROCK FROM THE CBBC WEBSITE!
IT FINISHED AND WENT INTO AN UPDATE! WHEN IT NEARLY FINISHED IT SAID UPDATE ERROR PROBLEM 106!
hey i don't know why cbbc has this game download if it doesn't work!!!!!!!!
I went to the measage board and all their help was just tell your perent or gaudian.
big help
After downloading Adventure Rock in Vista and running AR for the 1st time, after a long Adventure Update session which appears to be nearly complete, I receive the error 101
MINE SAYS ERROR 101
my computer is really slow so it took me over an hour to download this game then i turn it on waiting to play and it says error 101. i dont understand any of their advice on the web site!!!!
i download it it say u have problem 101 want the hell
it took me over an hour to download and then it tells me ERROR 101 is stopping me from playing the game
error 101
i can not play the game Adventure rock.
plz help me by mohamed
adventure rock error wil apear if i try to get on
it wont let me download adventure rock and then it says error page not found. can you help??
it says error 101
