Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
SOURCE: Pictures on Internal Memory
Select Backup from the Setup menu to copy pictures from the internal memory to a memory card. This is a copy, not a move, leaving internal memory untouched. It also does not affect any favorites.
SOURCE: memory full
You will have to check this out on the manual. There is a full manual on the software CD
SOURCE: internal memory photos download to sd card
Press the menu and look for the utilities section on the camera. There should be a copy from memory to SD.
SOURCE: how to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
