Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine acts like it is vapor locking.. Can Mow 30
Engine acts like it is vapor locking.. Can Mow 30 minutes then engine shuts down sounds like running out of fuel. Already cleared the gas cap vent just to be sure. If you wait just 1-2 Minutes it fires right back up. But will not hold a load can only drive not cut. If I wait till it cools down I can cut 30 minutes again. Changed fuel filter but not with a craftsman filter. My old fuel line fron filter to carb just fell apart so I did replace that.
    New Friend:
  • 148 Answers
Heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
Posted on Jul 11, 2010
    New Friend:
  • 51 Answers
Could have a bad ignition coil.when coil gets hot wires expand loses contact inside when cools down remakes contact. when engine shuts down check for spark right away
Posted on Jul 18, 2010
6ya staff
SOURCE:
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
MY ******* WILL SHUT DOWN AFTER ABOUT 30 MIN OF MOWING LET COOL OFF ABOUT15 MIN WILL START WRIGHT BACK UP AND MOW AND WILL DO IT AGAIN CAN YOU HELP ME
You have a Ignition Coil (Module) going bad. This is how they act right before they quit completely. You may be able to pick one up used pretty cheap from a small engine shop.
Good Luck!
Jim
Aug 10, 2011 | Garden
2007 Land Cruiser stalls to idle and non responsive to gas pedal
Had exact same problem after driving 120 miles in Florida heat. After 30 minutes started but ran rough for a day and now seem fine. Thought at first fuel filter or dirty gas. Going to replace filter anyway. Is this a common problem?
Jul 09, 2010 | 2007 Toyota Land Cruiser
Must wait 30-40 mins to restart engine
Check your manual to see if it call for premium or regular. Premium has less energy per gallon and is designed for higher compression engines. What makes it "premium" is more anti-knock compounds - not better quality or performance. Sounds like a vapor lock problem that resolves as the engine cools. Regular gas may help with that.
May 03, 2010 | Briggs & Stratton 3000 PSI Pressure Washer
Truck starts and runs great, but if the temp gets past a certain point it starts acting like its starving for fuel then dies. after 30 minutes or so of cooling down it cranks and runs like there was never...
If the temperature is exceeding 210 degrees you are at risk for overheating your truck and it shutting down is a good thing. If it is exceeding this temperature range, buy a new thermostat (very inexpensive and easy to change) located where the main radiator hose enters the engine block. This will also help keep your temps under control and if you have never changed one before on this truck, it's time to do so anyway. If the problem is happening before 210 degrees......I'm not really sure what the problem could be except that the heat coming off the engine is vaporizing the fuel before it hits the cylindars thus causeing to act like it is starving for fuel.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 12, 2009 | 1988 Ford Ranger
I can drive for 30 min. With no prob. After that
Sounds like fuel vapor lock. When fuel is heated, it will change from liquid to gas.... gas bubbles don't feed very well through injectors or throttle bodies.
Inspect your metal fuel lines under the hood, most likely. See if a metal hose is touching the engine, especially the near or on the exhaust manifold. You might want to insulate the fuel lines (Lowe's or Home Depot $4) with pipe insulation.
Sep 25, 2009 | 1994 Toyota Tercel
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Acts like vapor lock
when they went to fuel injection the fuel that was not used returned to the tank thus cooling the fuel and ending vapor lock, my question is did you do a fuel pressure test? and di you do a fuel leak down test? and the first thing I would do is change the fuel filter. with ethanol in the gas it kills the filter. I have to replace mine every three months they just plug up from that junk. Other than that the only other thing would be a coil breaking down when it gets hot the coil shorts out when cool it starts so check those things first. be sure fuel pressure is 50 to 60 PSI and does not drop below 30 PSI for at least a minute, if it does the fuel pump check valve is bad, also the fuel sock could be bad as well.
Jun 25, 2009 | 1989 Oldsmobile Cutlass Cruiser
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
918 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
