I have a sony kdf-50we655 tv it shuts off by itself the front light blinks and the tv turns back on. i had to replace the lamp about 3 mouths ago. in the past weak are so the problem started. i have removed the back cover and cleaned the fans this hepled for a day or two but the problem is back
SOURCE: SONY KDF-50WE655 Cooling Fan
There are three fans: 1)Cooling fan(on the optical block)part# 1-787-057-11 2)Ballast fan part# 1-787-081-11 3)Upper optics fan part# 1-787-460-11 Also make sure you don't have a noisey iris motor in the optical block (verify by adjusting the iris settings in the menu and see if the noise level changes)
SOURCE: Blue Dots
I have the KDF 42WE655 with the same blue dot issue and Sony upgraded me to the KDL 46V4100 for $375! I jumped on the opportunity.
SOURCE: Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
I fixed my problem by removing the lamp and vacuuming the hell out of the hole where the lamp lives and also getting all of the dust out of the rear ventilation grids with my vacuum. I put the old lamp back in and what do you know the TV has worked perfectly ever since. My lamp was over a year old and did not show any signs of hazing on the lens that you might see on a lamp that has a ton of hours on it. I just thought I would try to put it back in before I spent a couple of hundred bucks on a new lamp.
TA DA problem fixed.
SOURCE: I have a SONY LCD TV model KDF 50WE655 w/ Blue Dots on screen :(
The blue dots are cause by a defective optical light engine. This parts is quite expensive.
Read the info from this link for more info.
