my COOLPIX L18 camera, when i turn it on, has a blank white screen & a diagnolisitc crack on the inside, and because of that, i can't really know the accuracy of the picture i took; however, im still able to take pictures, but it just won't display what im taking a picture of.
So im asking how i can get it fixed?
SOURCE: Nikon coolpix L18 Screen has
Chances are the manufacturer will not accept damaged screens. If you've got a new camera, try your luck. Cracked screens are highly unlikely as the screens are not under pressure or stressed from the way they are constructed. Much like the cellphone screens, they are pretty tough to break. I broke mine after more than 15 accidental drops.
SOURCE: broken nikon coolpix L18 camera screen
The same thing happened to my 2 week old L18. I called the Nikon parts department and they want $59 for a replacement screen. I'll take the camera apart tonight and see if it is easy to replace.
Nikon Parts Department 1-310-414-8107
L18 Screen part number: 0299-9042-60090
$58.63
SOURCE: Nikon Coolpix L18 Driver
You don't need the disk to transfer your pictures from your camera to your computer. Just take your sd card out of your camera and plug it into your computer. A folder with your pictures will appear on your computer. Copy them to a different folder on your computer, so you can take your sd card out and still have them on there.
If that doesn't work, plug the cable in that came with your camera, and hopefully that will work.
I hope this helps. Please rate my solution.
Try this, it may work without the software. Turn off the camera. Plug the usb cable between the camera and the computer. Turn on the camera. If a box pops up on the computer asking what you want to do, scroll down and see if there is an option to view pictures. If a window opens up with all your pictures on it, great. Now open up a folder where you want to put your pictures. Bring up the other window with the pictures in it and hit the control key and the d key at the same time on your keyboard. Then drag your pictures to the window where you want them and let go of the mouse key. They should all move over. Then you can use Windows image viewer to see them. Let me know if that works.
SOURCE: I have lost the original software CD of Nikon Coolpix L18 camera. How can I get a download?
Most often the manufacturer will have a support and downloads area on their website. You may find what you need here: http://www.nikonusa.com/Service-And-Support/Download-Center.page
is there some small spot on the screen or maybe some black thing. it is due to the lcd screen liquid leaks out.so the lcd seems so blurry.
http://www.digitalcamera-parts.net/
e-mail:[email protected]
