Question about Whirlpool AWM8163 Front Load Washer
Error code FH on my AWM, what does it mean?
As soons as I put on the washing machine after a few minutes the error code FH appears and the wahing machine stops working, what does it mean?
Br Cecilia
    President:
  • 1,382 Answers
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Posted on Jul 12, 2010
    New Friend:
  • 139 Answers
Kenmore he4t washer error code (fh)
clip this post email this post what is this?
see most clipped and recent clippings
Posted by cat88 (My Page) on Sat, Feb 25, 06 at 18:32 Hello, has anyone had the fh error code on their washer machine, and want ended up being the problem. I know that the code means water inlet problems ,but I check inlet hoses and filter all seems good. drain pump seems good with plenty of pressure draining from hoses. sears wants $60.00 + parts and labor. or purchase 1 year warranty for $190.00 that would cover all cost up to $500.00.Just wanted some opinions before they come out. Thanks Craig
Follow-Up Postings:
error code FH on my AWM, what does it mean? - bull2.gif RE: kenmore he4t washer error code (fh)
Have the water flow meter checked or replaced. If the internal wheel sticks inside the meter, the CCU will think no water is entering the washer and give you this error code. Do you notice an above normal amount of water in the washer when you notice the error code? This is a good indication the flow meter is faulty. You can obtain the part from Sears and install it yourself. Very easy fix. RE: kenmore he4t washer error code (fh)
Hi, yes it is when the washer is full, when the washer has completed it wash cycle and goes into the drain and rinse cycle. do yoerror code FH on my AWM, what does it mean? - bull2.gifre this meter is located Thanks Craig bull2.gif RE: kenmore he4t washer error code (fh)
Hi , Found flow meter, took it out, blew though it with mouth and wheel seem to move freely. also check inlet valve solenoids had a ohms resistance across the 2 terminals on each solenoid.was told if bad werror code FH on my AWM, what does it mean? - bull2.gifw a direct short. any other thing I could check loose connections ect. Thanks Craig bull2.gif RE: kenmore he4t washer error code (fh)
The flow meter has a reed switch on the side of it. Sometimes this switch fails and doesn't respond to the magnetic wheel inside the flow switch. It is suppose to provide a pulse action as the wheel turns. The CCU interprets these pulses to determine flow rate. Just because the wheel inside the meter turns, does not necessarily mean the reed switch is funcerror code FH on my AWM, what does it mean? - bull2.gif Exactly when do you see the hf error. At the exact moment you see the error is the washer's water level higher than normal?
Hi , The exact time is 8 minutes into the cycle ,when it is done with the wash cycle, there is a click the fh light flashes and there is a bleeping noise and it begins to drain,it drains all the water out then stops. yes the tub is full of waerror code FH on my AWM, what does it mean? - bull2.giffh flashes and begins draining. why would the fh not flash when tub is filling up if wheel sensor was bad. Thanks for all your time and concern it is gratly appreciated.Craig bull2.gif RE: kenmore he4t washer error code (fh)
Hello. In reading the fh error code statement, It states error code FH on my AWM, what does it mean? - bull2.gifinutes and 10.5 gallons of water flowing though the flow meter it should receive a code from the pressure switch, this is happening exactly 8 minutes into the cycle could the pressure switch be the problem? Thanks Craig bull2.gif RE: kenmore he4t washer error code (fh)
Helloerror code FH on my AWM, what does it mean? - bull2.gifeeping you guys up to date . check pressue switch ,blowing air into it hearing click, then releasing air and hearing click again. blew air opposite way into drum and it seemed clear with tub drained.read this on the internet, seems to be working find. Thanks again bull2.gif problem may have been solved
  • Posted by cat88 (My Page) onerror code FH on my AWM, what does it mean? - bull2.gif 25, 06 at 23:51
Hi, well after blowing air back into drum and into pressure switch the washer is working proper again, I can't explain what cause this other than maybe it being slightly blocked at the drum or pressure switch ?Thanks for all the help and maybe this will help someone out later .Craig bull2.gif RE: kenmore he4t washer error code (fh)
Congrats on your DIY repair! There may have been an obstruction in the air line between the drum and pressure switch you dislodged by blowing through the tubing. You may have also freed a stuck or sticking contact within the pressure switch by manually applying air pressure to it. I believe you can normally hear two clicks when gently applying air pressure on the switch and then a third click with more air pressure (over-flow trip). Fortunately these parts are relatively inexpensive to purchase and you can install them in a couple of minutes of removing the top panel. I'm assuming your washer is over the one year mark so I would also recommend running a cleaning cycle to dissolve any accumulations in the washer that may have caused this problem (where air tubing connects to the lower drum). Use Cascade Complete dishwashing detergent (I use .5 cup of powdered version) and run the machine on the Sanitary Cycle. Smaller machines than ours can use slightly lessor amounts of the detergent. After operating the washer a few minutes to completely dissolve the detergent, pause the washer, open the door and swab down the complete bellows assembly including the hidden folds and adjoining areas where the bellows attaches to the drum. Go around the entire perimeter of the bellows and adjoining drum, concentrating between the 8 & 4 o'clock positions where lint and debris collect the heaviest. Then throw a couple more rags in the machine to aid in splashing the solution and let the cycle complete. The enzymes will dissolve any bio-film or other build up that may have accumulated over time. Don't add any chlorine bleach to this cycle otherwise the bleach will destroy the enzymes. Make sure to also wear hand protection while doing this because the solution is harsh.
This cleaning cycle is more important if you use mostly cold or low temp wash temperatures and/or tend to be skimpy with detergent dosing. To be on the safe side I complete this cleaning routine about once a year. I use at least a few Sanitary Cycles per month and also use the Stain Treat cycle often. Owners that don't, should run this routine more often. After nearly five years of use, my HE3t still remains spotless and sanitary.
One last remark on the diagnosing of the pressure switch and flow meter. The pressure switch will normally trip its first set of contacts within about a minute or less of filling at the beginning of a wash phase (not rinse phase). Then the water solenoids will start increasing the water level in increments (Catalyst function). You can tell if the pressure switch is malfunctioning if there are no on and off cycles of the water solenoid valves during the initial fill phase. If the water enters in a constant manner without pauses, the pressure switch has not tripped it's first set of contacts. This pausing only occurs during pre-wash, auto-soak and wash phases. This is considered the "Catalyst" portion of the fill where concentrated detergent is gradually applyed and dissolved into the laundry for improved cleaning performance.
At this point (if no pauses are detected), the tubing connecerror code FH on my AWM, what does it mean? - bull2.gife pressure switch should be checked for air leaks, disconnection or obstructions. If the Catalyst function is operating fine (water pulses on and off), the culprit of an HF error is normally a malfunctioning flow meter. A good indicator is substantially higher water levels than normal, provided the flow switch has tripped its first set of contacts.
Hi, Thanks hbw258 you have helped us diagnosing are problem and help save us a 190.00 bill. just a few questions in cleanig the drum ,tube and pressure switch, I can't open the door and clean inside on our washer because it is a front loader, or add any clothes during wash because the door locks during wash.Should I still do the cascade wash?
When blowing air back into drum there seemed to be some resistance in airflow, is this normal?.
I watched the washer fill with lid off and the water inlet solenoids do cycle water on and off a few times doing fill up so the pressue switch is working properely now ,error code FH on my AWM, what does it mean? - bull2.gifure what it was doing prior to blowing air though it ...
and yes my wife uses mostly cold water and is probably tight with the detergent.Wife has been washing clothes all day( 2 teenage boys) and all seems well. Again Thanks HBW258 For taking time out of your busy schedule to help a total stranger as myself you should and probably do feel good about yourself. Craig + Sheila+ family....... bull2.gif RE: kenmore he4t washer error code (fh)
You're quite welcomed and glad you could get your machine operating again. Your HE4t can be paused after it fills anderror code FH on my AWM, what does it mean? - bull2.gif should unlock so you can clean the bellows as I described above. Just press the pause button once. The display should start flashing indicating you're in the pause mode. The door should then unlock within a few seconds. Then you can complete the cleaning routine as described above. It's best to use the high temp Santiary Cycle for this routine. There will be some resistence when blowing through the pressure switch hose. This is normal.
Hello, Just me again with a update, Hbw248, While doing the cascade rinse the fh error reappeared, So I took the top + back of washer off cleaned the plastic therror code FH on my AWM, what does it mean? - bull2.gifressure switch hose connects to on bottom of drum (was a little dirty )soaked it, then blew it out.inspected the rubber hose and long and behold there was a hole in the rubber hose were it was rubbing up against another hose about 2 inches long and was paper thin,you could air coming out of it when you blew though it, it was loosing its pressure though this hole, this should be the problem. my question is can you used regular quater-inch black hose from the hardware store. Thanks Craig bull2.gif RE: kenmore he4t washer error code (fh)
You can probably use any flexible tygon type tubing that you can get to slip onto the fittings. I've seen silicone based tubing at hobbie outlets that deal with radio controlled boats and cars. Silicone would be more flexible and stretch over the fittings easier. Let me know what you end up using and good luck with your repair. bull2.gif RE: kenmore he4t washer error code (fh)
Hello, I used 7/32 i.d. black rubber vacume hose for cars from auto parts store, closes thing I could find, I think the original hose is 3/16 , it was somewhat tight, not as tight as original. but seems ok, have washed 3 loads, so far so good, the original hose was placed in a area where it could rumb against drain hose during washing,tried to locate new one by itself keeping it the same length. Thanks again hbw248 for all your help.Hope this does it.......... bull2.gif RE: kenmore he4t washer error code (fh)
hello hbw248, I have the exact same problem as cat88 on my HE4t. However, I'm getting the 'FH' error code much error code FH on my AWM, what does it mean? - bull2.gifto the cycle; approximately 2 minutes. The interesting thing is that jiggling the connectors between the flow meter and CCU, the washer resumes normal function. Then, it returns the same error code for the next load. Every time that I slightly re-adjust the connectors or removing and putting back the flow meter, the error code seems to go away. I'm afraid that my problem is not the flow meter, but the connectors. In addition, I'm also suspecting the chip on the side of the flow meter not functioning correct. Is this the detector of my pulses inside the flow meter? Any help would be greatly appreciate. Thank you. bull2.gif RE: kenmore he4t washer error code (fh)
clip this post email this poserror code FH on my AWM, what does it mean? - bull2.gifan>what is this?
see most clipped and recent clippingsMy Kenmore front loader is flashing on and off and won't allow me to start the cycle? Does anyone know what this means and how I can correct it myself? bull2.gif F2 error code
Does anyone know what the F2 error for the Kenmore HE4t means? bull2.gif RE: kenmore he4t washer error code (fh)
We have a Kenmore HE3T. It's getting the HF error. I read thru all the helpful information posted above. I timed the occurance: 10 1/2 minutes after I push start the error happens. The water does come on and off in the beginning for a couple minutes, then runs constantly while filling. The tub has A LOT more water than usual when the error comes on. This is making me think it's the pressure switch or hose. It's done it for 5 loads of wash in a row today. When the error flashes and the machine beeps, it doesn't drain on its own. I have to push the drain/spin button. The first poster had his drain authomatically. When I do tell it to drain, the water comes out quickly. Yesterday, I ran a load with too many paierror code FH on my AWM, what does it mean? - bull2.gifns in it, and I think I must've messed up the machine. I had to pull some out to get it to spin correctly. It makes me wonder if the pressure switch hose could've gotten messed up with a heavy load in the machine - I read above how someone's had a hole worn into it - ? I think it must be either the hose, pressure switch or water valve. Is this thing repairable without the repair manual? My husband has replaced the water inlet valve on our old top loading machine, dishwasher, fridge, so is this something a handy hubby can do? Sears gave me the same repair warranty offer of $194 for 12 months which includes parts, trip and labor. If the parts are expensive, plus if we have to buy the repair manual, the warranty might be worth it. What do you think? bull2.gif RE: kenmore he4t washer error code (fh)
  • Posted by juliemomof6 ( RE: kenmore he4t washer error code (fh)
    see most clipped and recent clippingsI have the exact same problem. However, I am a female with no "washer repair" experience. Can anyone tell me where the pressure valve is located? I would be willing to blow into it if it helps, therefore cutting out the costly Kenmore repairman. Thanks, guys. bull2.gif RE: kenmore he4t washer error code (fh)
    Hi, I have gained a lot from readingerror code FH on my AWM, what does it mean? - bull2.gifead and searching this forum, but I'm not sure if I've found someone with exactly the same problem I'm having. My machine starts, fills up some on and off as described above. However within a minute or two of the cycle will display the FH code. If I hit pause, then start again, it will resume tumbling, adding and draining water then FH again within another minute or two. It is definitely not an overfilling issue.
    My machine was just purchased used, and had some ice issues, (despite the seller's assurance it was properly drained) I'm thinking it is likely the flow switch is bad, but could these symptoms be related to the pressure switch instead. I've already replaced the inlet valve, and it seemed to allow plenty of hot and cold water in; at least until the FH code appears.
    Any guesses as to how to troubleshoot this further? Or should I just replace the flow switch.
    see most clipped and recent cerror code FH on my AWM, what does it mean? - bull2.gif/a>
    I had the same problem. As soon as Rinse cycle started one valve would not open (or so it seemed)and the washer would stop. After switching the wiring connectors on the valves and seeing that the problem went away because the other valve did open, I thought it was a bad valve. I put the wiring connectors back to original and then switched the hoses coming in from cold to hot and hot to cold. Now the other valve seemed to not work. The problem was in the "Floodsafe" feature of the supply hose (shuts off if flow exceeds 2.5 gpm) Reset the hose and all is well. bull2.gif RE: kenmore he4t washer error code (fh)
    clip this post email terror code FH on my AWM, what does it mean? - bull2.gif/a> what is this?
    Had a similar problem with the FH Error Code. Water filled continuously until the high level was reached which was apprarently causing the FH error code. Turns out it was a hole in the Pressure Line going to the Pressure Switch causing a failure in the water level measurement. I removed the pressure line, blew air into it, and immediately located a hole in the line. I taped the line temporarily and the problem is resolved. This was an EXCELLENT Post. bull2.gif kenmore he3 washer error code (fh)
    Thanks for those who posted the possible fixes. My Kenmore HE3 had the FH error after about 8 mins of cycle start. The washer would fill up with water and then stop. After that it was at least possible to drain the water by stopping the cycle and running the drain cycle.
    As per suggested solutions:
    1. First I removed the flowmeter from the rubber hoses that held it and blew air threw it. Also checked the resistance using an OHMmeter and found 0 ohms when nothing blew threw it and showed resistance when the wheel spun. Replaced it back, but the problem persisted.
    2. Next, I found the black soft rubber hose/tube connected to the pressure sensor which is a red disc plastic part on the right upper side towards the back of the washer. I error code FH on my AWM, what does it mean? - bull2.gifngers along the tube that went down and towards the back of the washer and found it connected to the main drum. When I felt the tube down there I felt it weak and flimsy at one spot. It was where it was touching the drum and perhaps the rotating wheel of the motor. I pulled it off and disconnected the tube (about 2 feet long). Just as someone said, it was worn out (as if someone scraped it with a fine sandpaper on a 2 inch section) and there was a really tiny pinhole at the center of it.
    Went to a local hardware store and got a clear vinyl tube (like the ones used for aquariums) - 3/16th inch inside diameter and replaced the soft rubber tube. Store did not have a rubber tube. Hopefully the vinyl tube will be more durable than the soft rubber, though I see why the rubber is useful to allow drum movement, but vinyl I think is soft enough for that too.
    Routed it from behind the drain pipe to keep it away from the derror code FH on my AWM, what does it mean? - bull2.gifr as possible. Started the washer and works perfectly.
    Hope this helps!
    Where is the flow meter located? Is it labeled? I am having the exact problem but did not see where anyone said WHERE it is located or how to get to it. I am an idiot in a sea of FH codes. bull2.gif RE: kenmore he4t washer error codeerror code FH on my AWM, what does it mean? - bull2.gif>clip this post email this post what is this?
    I have tried all of the above mentioned techniques, back to 2005, to figure out the FH code. Have not resolved it. Installed new inlet valve. Still getting code 2 min after start. Any help would be appreciated. Really disappointed/frustrated. bull2.gif RE: kenmore he4t washer error code (fh)
    Where is the flow meter, the pressure switch...and, what is the CCU? Where is the CCU? My washer is giving the F/H error code and will not fill. There is water to the machine. I have checked and cleaned the screens. What panels do I have to remove to get to the flow meter, pressure switch and the CCU? I am getting NO water in the machine. It's starts tumbling w/o water then gives the F/H error code. Another reader was requesting the location of these parts...I did not see a response indicating the location of these parts. Please provide the location and general description of the flow meter, the pressure switch...and what the heck does CCU stand for? Thank-you tons!!! ...another single woman trying to make it on her own - your assistance will be greatly appreciated! :) (Times like this, I wish I were not alone...you know what I mean?)
    CCU = computer control unit or central control unit -- the computer board that runs machine. You can search your model number at SearsPartsDirect.com to see diagrams of the machine's parts and assembly. Typically the top panel comes off for access to the parts in question.
    bull2.gif Post a Follow-UpPlease Note: Only registered members are able to post messages to this forum.
    If you are a member, please log in.
    If you aren't yet a member, join now!
Posted on Apr 06, 2012
6ya staff
SOURCE:
Whirlpool awm 9000 I bought a used Whirlpool
The error code F/H for this machine means that the drain pump is blocked. Look at your manual for how to access the drain pump and clean it out. This will resolve your issue.
Oct 18, 2013 | Washing Machines
With 26 minutes remaining FH appears where the time is displayed and the wash stops. What does FH mean
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
May 03, 2011 | Washing Machines
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Nov 28, 2010 | Kenmore Washing Machines
Whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Feb 07, 2009 | Whirlpool AWM8123 Front Load Washer
We have a whirlpool 6th Sense AWM 6145/3 which has just started stopping during the wash cycle and on the digital display the letters F H come up. We rent our property and have moved several times and have...
FH is the code for no water flowing in...
is there water flowing in?
if there is none, the water solenoid is the problem,
if there is water going in, then the flow switch is the problem.
here is the transcript from the web..
FH ERROR CODE
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves
will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow sensor has
detected 48liters of water passing through it, but has not detected the pressure switch
trip, the valves will be turned off and the error code will flash.
and here is their solution
water source opened
flowmeter
pressoswitch
wiring to valves, pump,
flowmeter, pressoswitch
hoses
either one of those parts...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool Washing Machines
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Whirlpool AWM8163 Front Load Washer Logo
1,077 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
