Maytag dish washer makes loud humming sound, I removed kick plate and can feel motor shaft turning. tapped motor with hammer no sound change. no loose or binding parts
If it is your transformer it shou li d buzz all the time. Out an amp meeyer on the motor you suspect is going out. Check the bearing play by pulling on the shaft in and out. A littke p li ay is ok but not excessive in and out. If it moves side to side DUMP IT . The amp rating is on the maker plate.
bearings in the heater fan may get worn out or rust. If this happens, it may become very noisy, either grinding on the bearings, or scraping against the rust. If this happens you need to replace the fan motor. Sometimes, a fan blade may come loose, and you need to replace it. Sometimes it's the motor that makes the noise you hear. The motor has bearings in it which may become worn or get rusty. When the bearings get worn, they allow the shaft to wobble which can get quite loud. If there is a spin seal leak, water may get inside the motor, washing the bearing grease away. If the spin seal is leaking, you'll notice water leaking from under the dishwasher. There is also a disc attached to the top of the motor called a slinger. It sometimes breaks off and spins around the motor's shaft while it turns, causing some noises. You will need to replace the motor if the bearings are bad. You also need to replace the motor if the slinger is broken as well.
Newer dishwashers may make a squealing or rattling noise on the first run. This is because it has not had any water in it yet, and the motor seals are dry. You may hear this in a unit that hasn't been run in a week or more as well. You should operate the dishwasher regularly to keep the sump water from getting smelly, and to keep the seals lubricated. You can add a quart of water to the sump before running it.
Rattling noises may be produced by dishes rattling inside the dishwasher due to the water pressure from the sprayer arms on the dishes. To determine if the rattling is a loading issue, run the unit empty. If the sound is persistent, it may be that there is debris in the pump.
dishwasher water-inlet valves are noted to make a hum that lasts about 60-90 seconds several times during a washing cycle. This hum is a different hum than the sound of the motor running.
A rhythmic knocking or thumping sound may be caused the sprayer arms hitting something as they go around and around. Rearrange the dishes and resume the wash.
A clunking or clanking may be heard when the detergent cup opens; while a clicking sound may be produced by the timer or electronic control panel.
A solenoid makes a snap sound when it opens. This happens about six times during each load.
Pipes rattling or banging may be caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The sound is caused by the water slamming into the closed section of pipe. A plumber can install an anti-hammer device.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and then remove the item that is making the noise or replace the pump. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher. Send this page to your printer
mcdevito75 here, Sounds like the bearing in the fan motor is going out on you, Thses bearings are a sealed unit from the factory, check out any A/C repair shop in your area for repair.
The motor is frozen. Remove the bottom kick plate and with unit in off position take a screw driver or use your hands to turn the motor. You will feel the motor when it lets go. Close door and turn on dishwasher and you should be fine. Very common with the GE made dish washers.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
It's possible that the prongs have broken and the humming that you hear is the pieces rubbing against the center rubber piece.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Do not turn on again. You have an obstruction in the fan . You will need to remove the motor from the lower housing, dismantle the fan cover and remove the obstruction, possibly replace the fan as well. The lower housing plate can be removed revealing a set of clamps around the motor hosusing which will in tun release the motor from the base of the vac.
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
It seems that your motor on the dishwasher is going out, like mine has just done. My explanation is that it sounds like something is grinding on glass or as if a bunch of mice are making noise. Eventually, the motor will not run any more. What will happen is that the dishwasher will fill up, then make a loud humming noise, while the heating element is making the water near the heating element sizzle. Now what you have is a possible fire hazard which compounds the problem with the dishwasher. Get rid of it, take the loss and live like my grandmother used to, without having a dishwasher. That is the best advice I can give you.
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
