Upon putting on the LCD TV, it switches from power (green light) to stand-by (blinking red light) with no sign of power to the screen and speakers. If it is a burn out what part needs replacing? The warentee has expired.
The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com Ebay.com to buy a refurbish power supply board for the replacement.
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Feb 8, 2012 - 7 posts - 3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house.
Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012 Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012 More results from www.tomsguide.com
Missing: 32dv22u
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits. You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
This is a LCD projection could be problems in the LCD blocks. There is one for blue one for green and red.Also make sure the lamp is good and the door is closed right there is a switch there.
IIC bus clock and/or data lines low at power on
06. This is the fault, according to the blinking codes given by Sony LCD TVs. That is, the fault lies within the main digital board. To locate the exact fault point to these type of fault, is actually a skilled one. If you wish to get more details to this fault, check the link sited here.http://electronicshelponline.blogspot.com/ It has details about these blinking codes. Before proceed, once again count and make confirm the number of blinks occur at one time switch ON. Pull up older posts by this link at its left side bar.
May i know, what's your lcd tv brand and model? When the light change to red color, is it a steady light or blinking light? Or you need more info on repair lcd tv, please visit this site http://lcd-television-repair.com .It may be can help you solve the tv problem.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is. no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
