Hope you have adjusted with your remote. Even with this if the problem repeats, there may be resistor gone in high value or open.
Try the circuit associated to red gun ( cathode of the picture tube). If you have a digital meter, switch OFF TV and give a check on all the resistors. Check whether any value is changed to higher side.
If you notice any ohmic value changes replace them with identical type.
If variable potentiometers are provided try adjusting them. But note down the orginal position.
If it is service mode adjustment, contact SONY service center as the service pass word code is known to them only.
