Computers & Internet Logo
Posted on Jul 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have type 4 utstarcom modem.my modem restarts now and then,dsl light goes on blinking and i loose net connection. is it the problem of modem?
Anonymous
Level 3:
  • Master 524 Answers
  • Posted on Jul 13, 2010
Anonymous
Master
Level 3:
Answers
524
Questions
0
Helped
174977
Points
1756
Hi....
this may be because
1.of the modem problem also
2.votage fluctuations.when the voltage comin to modem falls the modem gets off and when you get it right then it starts again.
3.the net gets connected only when the DSL light is glowing continously.As the modem switchs off and starts up again it takes time for the DSL light to glow continously.
if my answer was usefull to you please vote me
  • Venukiran
    Venukiran Mar 02, 2015
    The modem does nt light up even when the voltage is right. I checked the adapter is good, but all the LED's on modem are off. Is it possible to get it repaired in Hyderabd?
tip
BellSouth AT&T Motorola Modem Red Light/s, No Internet
Modem, Router and PC
1. Press and hold the reset button on the back of your modem for 10 seconds to fully reset your modem to initial factory defaults.
2. Wait for the modem's Power and DSL LEDs to turn solid green.
3. Open your computer's Internet browser and your modem should launch a mini-setup routine. Enter your FastAccess DSL username in the format of [email protected], enter your FastAccess DSL password and confirm your FastAccess DSL password and click next, then there will be an "Auto Calender Update Configuration" page where you will set the auto update info and timezone info so just enter the info and click next.
4. Your browser will refresh the page and say everything is ready to go, this may take a few moments. When this is complete type 192.168.1.254 into your browser's address bar and click on the "Broadband DSL Line" tab, then on the right, click on Connection configuration.
5. Change the Protocol from the dropdown box to Bridged Ethernet Mode, and then click on Save and Restart Connection.
6. Open your computer's Internet browser again and type in 192.168.1.1 into your browser’s address bar. In the Internet Setup, change the Internet Connection Type to PPPoE and enter your FastAccess DSL username in the format of [email protected], enter your FastAccess DSL password and click on Save Settings.
7. Close all windows and restart your computer. Your internet should now be working.
Modem and PC
on Jul 24, 2010 • Computers & Internet
DSL NOT STANDING.
If you are having trouble with the modem, call your isp to get this trouble sorted out.
Dsl light goes beyween blinking green, then goes solid red, then back to blinking green. Cannot connect to internet anymore.
The modem cannot get a signal from your service provider. The DSL light is an indicator if your modem is communicating with the network of your service provider. DSL light should always stay solid green. Try contacting your service provider. It might also be an indication of a bad modem.
1helpful
CNet wireless router Model CWR-854V. is causing my Ethernet lite on my DSL modem to blink causing me not to be able to get on internet. Changed all cables no help disconnected Router and modem works...
Use an Ethernet cable to connect your computer directly to the DSL modem, bypassing the router, turn the modem off, turn the modem on, wait 60 seconds, and restart your computer.
Does the Ethernet lamp still blink when Windows is booting, and when you are using the Internet?
Turn the DSL modem off.
Turn the router off.
Turn the computer off.
Disconnect the Ethernet cable from the modem, and connect it from the computer to the router.
Turn the router on, and wait 60 seconds, then turn your computer on.
After Windows is running, click Start.
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: default gateway........ 192.168.123.456
If the string starts with '192.168', then your computer *IS* "talking" to the router.
Now, use an Ethernet cable to connect the WAN port on the router to the DSL modem.
Turn the modem on.
Turn the router on.
Wait 60 seconds.
Restart your computer, and you should be able to web-surf.
5helpful
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
15helpful
3answers
Assistance with blinking light on my DSL modem
First thing to do is unplug your DSL modem and leave it unplugged for about a minute then plug it back in and see if problem is corrected. If not you should contact your ISP tech support. You could have a bad line from the phone company or bad connection in your house. Also if you have filters installed on your other phones you can have a bad filter that is causing interference and keeping yoiur DSL from working properly. You should go to "Start" > "Run" and type cmd and hit "Enter"
In the command window type ping google.com -t (Enter) This will start a continual ping. If you are getting ping times exceeding 70 - 120 ms that could be a sign your DSL is not functioning properly or if you get packet loss. That is when the ping time doesn't return a time periodically.
2answers
Modem, all lights come on, dsl light blinks red...what does this mean?
It, means either your username pass word is not correct or the DSl line issue,
Grand Canyon Tech
Grand Canyon Tech
