Have a mitsubishi hd 1080 when the power is turn on it will go right back out the green light come on for about 3 seconds I have unplugged the set overnight and also moved it further away from the wall nothing has helped
Based on the model number WS65511, this set has a self check.
Turn on and when green power light goes out:
On the front of the set press and hold BOTH the MENU and INPUT buttons for at least 5 seconds and then release both buttons.
Power light will blink a two digit "error" code.
The most common is 2 blinks, a pause and 2 blinks. Set will repeat the error code at least 5 times.
Let me know what error code you find and I will tell you what it means, I hope you find it is 2,2 as that is the most easy to fix.
SD TECH Steve
mine does the 2 blinks a pause and 2 blinks do you know what the cause is
I had the same problem, TV would click back off after 3 seconds with a code 22...needed IC and pico fuses replaced...works like a champ now.
I got the kit from tvrepairkits.com...great product and great service.
my timer just keeps blinking after doing the menu and input at the sametime
The green light blinked twice, 10 times
Yes
mine is flashing 2,3 so whats wrong with it?
