HP LaserJet 1320 Printer Logo
Posted on Jul 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a flashing Yellow triangle on my Hp LaserJet 1320
Vasil Hristov
Level 2:
  • HP Expert 222 Answers
  • Posted on Jul 14, 2010
Vasil Hristov
HP Expert
Level 2:
Answers
222
Questions
Helped
107919
Points
540
Hello, this error means:
Paper tray is empty
Door open
Paper jam
Misfeed from tray
  • Vasil Hristov
    Vasil Hristov Jul 14, 2010
    Also you have to chek toner level by pressing and holding big green button for much than 6 seconds ( till all lights starts flashing) then release button = Configuration Page, Supply status page and Network settings page will be printed
    Hope this hint will be helpfull for you!
! in triangle symbol of HP1320 printer flashing. Only light. Cartridge door closed. Troubleshooting says all is well. Print job goes to queue, then disappears as done, but nothing prints.
On the HP LaserJet 1320, the attention light is a generic alarm. It can mean out of paper, paper jam, paper misfeed, cartridge missing, or cartridge door open. You can try cleaning the pickup roller or changing the separation pad. You can find these maintenance steps in the user manual starting on page 73 (page 83 of the PDF). HP has the manual here: http://h10032.www1.hp.com/ctg/Manual/c00208215 . More guides are available on the product page: https://support.hp.com/us-en/product/hp-laserjet-1320-printer-series/410622/model/410624/manuals . Amazon has the separation pad available here: https://www.amazon.com/RM1-1298-HP-Separation-Tray-P2015/dp/B009SPB1H4 . Links to replacement pickup rollers are on this page. There are probably other sources for the parts as well.
Unfortunately, it can also indicate that a part has broken from paper pickup unit or the door closed sensor isn't working. At my home when our LaserJet 1320 reached ~10 years old, we got this message and decided to replace the printer. It wasn't worth trying to locate and repair the problem when cleaning the pickup roller and paper path didn't work.
I hope this helps.
I have an HP Laser Jet 1320. The error light with the triangle and the explanation point is flashing. There is no paper jam. I have turned off the unit and plugged it back in. Can you please tell me what...
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
Triangle led keeps on blinking and icant print on hp 1320
Make sure that the toner isn't empty, and is seater correctly. Make sure that there is paper in the printer and also check every door on the printer to make sure that there are no paper jams anywhere. If there are also other lights blinking, go to the HP website and download the manual for this printer for more specific reasons for the error.
1helpful
HP 1320 will not power up
There actually was a misfed sheet, hidden at the very bottom of the lower hinged back panel. The reason it was misfed was that this panel had somehow gone off one of its hinges. Ironically I did not discover the misfed sheet until I had taken the printer down from its shelf and turned it over to read the serial number to the extended warranty tech support guy.
Moral: Open every panel carefully, check for misalignment. These printers have flimsy plastic parts.
8helpful
2answers
Hp desktop 1320 printer has yellow light on - it the icon symbol
The symbol for toner low is a box, without a top, with an arrow made of dots pointing up. Insert an new print cartriage.
Yellow light is blinking
I ahve the same problem and HP is absolutely NO HELP!! I'm ready to trash a printer that has hardly ever been used.
k24674
Grand Canyon Tech
Grand Canyon Tech
