Dewalt XRP hammerdrill 18 volt
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
SOURCE: all i need is the schematic for a dewalt hammer
go to Dewaltservicenet.com and in the middle of the page type in your model number and you can download a breakdown for this tool. If I have answered your request would you please rate this response accordingly.
SOURCE: the chuck is stuck on 18 volt dewalt drill
It is not the chuck that is stuck, it is probably the armature. Probably a problem with the brushes. Since it is so easy I would try first unscrewing the caps and pulling the brushes out to see if things spin then. If the brush will not come out then it is probably jambed and you would have to take the drill apart. If you take the brushes out and still have a problem, at least one reasonable but simply checked problem is eliminated.
SOURCE: i have a 18 volt xrp dewalt battery that it das
replace bat.try northerntool.com. i bought a couple of after market ones for mine and so far so good
