I have a maytag performa dryer that sometimes wont dry clothes. no heat.
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element
Often a dryer heating element burns out, but
doesn't trip the circuit breaker or blow a fuse. The heating element is
simply a long coil of special wire. You can check it for continuity with
an ohm meter. No continuity means the element is bad and you need to
replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to
the exhaust duct inside the back cover panel. The fuse--which is about
an inch long--is usually embedded in black resin and mounted in a white
plastic housing. If the fuse has blown, you need to replace it. (You
can't re-set it.)
Wiring
A common problem is for the main wiring connection
from the house, at the dryer, to burn and break its connection. Because
the dryer can still tumble with partial power, the connection may be
only partially defective. You may need to replace both the power cord to
the dryer and the terminal block inside the dryer that the wire is
attached to.
